Old 04-18-2018, 07:03 PM   #1
l79m20
Question Testing old springs
My son bought a rebuilder 1971 chevy 1/2 ton short bed step side and is going to replace original rear springs with new. My question is how can a guy check the tension on the old springs to see if they are still usable as i have one sagging rear spring that I would like to replace with one of my son's take offs. I know I can replace with new but don't want to spend the money. TIA
l79m20 is offline   Reply With Quote
Old 04-18-2018, 08:01 PM   #2
PGSigns
PGSigns's Avatar
Re: Testing old springs
Change them as a pair.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-18-2018, 08:14 PM   #3
l79m20
That sounds reasonable but want to make sure the stiffness of the springs are still at oem specs, that is why I wanted to know about spring stiffness testing and how to do it.
Old 04-18-2018, 08:57 PM   #4
LVPhotos
LVPhotos's Avatar
That's a spring shops job... they build and have machines and knowledge. Going out on a limb but 40 year old Springs are gonna be badd
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 04-18-2018, 08:58 PM   #5
LVPhotos
LVPhotos's Avatar
Ever hang out at lowes or home depot no one ever overloads
Old 04-18-2018, 09:06 PM   #6
l79m20
That makes sense sounds like new is the way to go, thanks for your input. Do you know what these oem springs are rated at?
Old 04-19-2018, 06:45 AM   #7
PGSigns
PGSigns's Avatar
Here is some information on the spring rates.
Jimmy
http://67-72chevytrucks.com/vboard/s...t=spring+rates
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
