Old 04-18-2018, 10:54 PM   #1
Noah96
Brake Problems
Hey all have a question about my brakes. Have a 1969 C2500 with brake booster equipment. When I try using the brakes the pedal goes down to the wall. The brake cylinder doesn't leak fluid and stays full. Bled brakes didn't get any air when bleeding. May have messed up when I bled the only thing I can think of since I have no fluid lose. Any ideas.
Noah96 is offline   Reply With Quote
Old 04-19-2018, 05:40 AM   #2
panhead59
Re: Brake Problems
sounds like a bad master cylinder. It doesn't have to leak to be bad.
panhead59 is offline   Reply With Quote
Old 04-19-2018, 09:37 AM   #3
applebmw
Re: Brake Problems
Your plunger in mast cylinder needs rebuilt, used to be able buy a kit. I have a good power brake master cylinder, from 70 c-10 I will let you have for $25, plus shipping... I replaced with chrome.
applebmw is offline   Reply With Quote
Old 04-19-2018, 02:51 PM   #4
hayhauler71
hayhauler71's Avatar
Re: Brake Problems
Take the brake lines off the master and get some brass plugs to block the ports. Pump the brake and if the pedal fades the master is bad.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 04-19-2018, 06:57 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Brake Problems
Your master cylinder is bypassing. If it is old, just replace it, so that you don't have to deal with a pitted bore.
~Steven
Simi Valley, CA
