04-19-2018, 09:11 PM | #1 |
FS stock height spindles powder coated & almost new
Reduced 50. + ship + pp fee USPSMO works
I got these in a deal with tubular control arms that had 71-72 ball joints in them I decided to use lowering spindles instead of these PO said they had 1500 miles on them and he converted to a coil-over suspension Here is the info from Western Chassis they verifyied that the are 1973-87 Chevy C10 Stock Height Replacement Spindles Replacement spindles for 73-87 Chevy C10, GMC C15 or Suburban. Great for disc brake conversions using late model front end on an early truck. $239.00 new from Western chassis I put Keith Lolife99 write up on conversions below I believe you can use these on 67 -69 if you want to convert if you change ball joints and tie rod ends depending on the year you are converting I would like to get $80.00 for the pair plus shipping and PP fees or a USPSMO Lolife 99 write up on conversions Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 04-23-2018 at 10:50 AM. Reason: Price reduction |
04-20-2018, 07:52 AM | #2 |
Re: FS stock height spindles powder coated & almost new
top
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
04-22-2018, 07:31 AM | #3 |
top
04-23-2018, 10:53 AM | #4 |
REDUCED top
04-27-2018, 10:35 AM | #5 |
Anybody
04-27-2018, 10:38 AM | #6 |
confirming these will fit 67-72 trucks with no mods and use 67-72 parts with them ?
04-27-2018, 11:20 AM | #7 |
Yes depending on year ball joints and tie rod ends will convert
04-27-2018, 11:31 AM | #8 |
shipping to 58271?
