Old 11-10-2003, 05:49 PM   #1
jcab
I need more money....
Caddy rear disc brakes
I have read that it is not that hard to put a late 70's cadillac deville disc brake rear end in a 71/72 chevy truck. My question is, is there any issues with putting it in a 68 chevy with 6 bolt coil spring rear end?
Jay.
'68 LWB C10
'74 Duster ("It's not Rusted out, it's been modified for weight reduction")
'91 Civic
'97 Saturn
'88 Celica AWD turbo (R.I.P.) 273 hp Mustang Killer
jcab is offline   Reply With Quote
Old 11-10-2003, 11:10 PM   #2
ShamrockCustoms
Project56 on hold
ShamrockCustoms's Avatar
those caddies have 5 lug. also, need to measure the hub-to-hub on the rear to see what the difference in overall length is going to be. if it is off too much, you will see clearance issues with your wheels and may need to get a different offset on your wheels to compensate for the change in rear length. also consider brake line pieces you will need to buy as well as a different master cylinder for 4 wheel disks. mounting will also be an issue, will need some welding done, will need to empty the rear and remove the axles.
good luck!!
Shamrock Customs
Forever-in-the-Future Custom Shop
2009 Mitsubishi Lancer GTS daily driver
1956 Chevy Stepside rodstoration on winter hold
ShamrockCustoms is offline   Reply With Quote
Old 11-11-2003, 11:56 AM   #3
jcab
Thanks, I was pretty sure that it would be quite a bit of work.
Jay.
'68 LWB C10
'91 Civic
'97 Saturn
Old 11-11-2003, 01:12 PM   #4
paintpyro
paintpyro's Avatar
I dont think people use the entire rear end. I believe they are just using the disk setup and maybe getting the axle machined. There should be something under search.
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 11-11-2003, 08:53 PM   #5
ShamrockCustoms
Project56 on hold
paintpro does have a point. you don't have to use the whole rear end. that would eliminate having to change brackets, however, you would still have to do work on the axle tube ends since they will not be the same and, of course, you would have to remove the axles from your rear end you have, which means almost the same amount of work as using the whole thing. but if you're going to change gears anyway, this would be no problem.....
however, i think that disk brake kits are already available for your rear end type. maybe cpp has them or possibly ece.
Shamrock Customs
Old 11-12-2003, 03:29 AM   #6
jay-dawg
chevelito
jay-dawg's Avatar
you might want to do a search on this. I remember someone doing the swap and taking pics. good luck.
jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 11-12-2003, 03:34 AM   #7
Chevy Wrench
former desert rat
Chevy Wrench's Avatar
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
Try this link...linky
Link not working, here is the address...
http://home.pacbell.net/bigiron/Arti...rRearDisc.html
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const.
Chevy Wrench is offline   Reply With Quote
Old 11-14-2003, 02:36 PM   #8
REDNEKID
Who said that?
REDNEKID's Avatar
Well I can't answer you question about the caddy brakes, but here is a pic of my '72 with a camaro rear-end...
REDNEKID is offline   Reply With Quote
Old 11-14-2003, 04:57 PM   #9
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
REDNEKID
what year axle is that out of?! And also... your u-bolts are lllllooooonnnnggggggg
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 11-14-2003, 05:00 PM   #10
REDNEKID
Who said that?
REDNEKID's Avatar
It is from the '82-'88 I think. And yes, they are waaaayyyyyyy too long! Work was done before I bought the truck. I just found out yesterday what rear end it was.
Founder 4-Wheel Discs Club!
Old 11-14-2003, 05:06 PM   #11
REDNEKID
Who said that?
REDNEKID's Avatar
Here is a pic of the disc...
Only thing that sucks is that I have two different bolt patterns. ;-(
Old 11-14-2003, 06:13 PM   #12
jcab
Thanks for all the info guys! Definately gives me things to ponder.
REDNEKID, what is the bolt patern on the camaro rims? I am guessing 4.25? (or 4.75, or whatever it is...)
(sorry, I am still new to Chevy's)
Jay.
'68 LWB C10
'91 Civic
'97 Saturn
Old 11-14-2003, 06:21 PM   #13
REDNEKID
Who said that?
REDNEKID's Avatar
To be honest, I cant remember right now, but I will post later for you.
Old 11-15-2003, 12:23 AM   #14
clean71
clean71's Avatar
My '68 has '79-85 eldorado brakes in the rear. However, I bought the whole rear end assembly with brakes from Dynatrac. It's a Dana 60 rear. Works great.
CPO U.S. Navy(Ret)
1972 GMC Jimmy 4x4 Custom
1972 GMC Jimmy 2x4 Custom
clean71 is offline   Reply With Quote
Old 11-20-2003, 12:37 AM   #15
pickup6772
pickup6772's Avatar
JCAB, I HAVE A POST ON HERE ASKING THE SAME THING.Seville Rear Disc Swap. MAYBE THIS WILL ANSWER A COUPLE OF QUESTIONS FOR YOU.
MIKE
'67 C/10 2WD LWB
'89 MERCURY GRAND MARQUIS LS
COUNTRY TILL THE DAY I DIE
pickup6772 is offline   Reply With Quote
Old 11-20-2003, 12:58 AM   #16
toytruck
5-7 dropped 87 CC Dually
toytruck's Avatar
Before you guys get too deep. Go price the calipers for the firebird and the caddy. I put 82 firebirds on my Chevy II calipers where about 200. rotors about 70. axle flanges turn down 50. and I already had the brackets. I still havn't got to the e-brake cables yet! Its cheaper to get a kit that bolts on.
I rather be in my 77 Sanger Picklefork Jet Hydro!
toytruck is offline   Reply With Quote
Old 11-20-2003, 01:54 PM   #17
jcab
pickup6772 - I saw your post after I started this one. Thanks
Toytruck - Thanks for the heads up on that. I don't need disks in the rear at all, just thought it would be cool to have. However I think that for the expense/work, it won't be happening for me anytime soon.
As always, thanks for all the excellent info
Jay.
'68 LWB C10
'91 Civic
'97 Saturn
