Old 04-21-2018, 06:41 PM   #1
Dodge68charger
Drop Coil Questions
So I Got Some Cpp Drop Coils and Went To Install Them In My Front Suspension. They Are 3 inch Drops. I Can Pull The Coil Out When The Suspensions At Rest. No Bumpstops installed yet. Anyone else Run Into This? Trucks a 70c10. Thanks
Dodge68charger is offline   Reply With Quote
Old 04-21-2018, 09:34 PM   #2
Jason Banks
Jason Banks's Avatar
Re: Drop Coil Questions
So...you put in the new coils and they are loose?
Or...You are saying you have no upper bumpstops installed and the old spring is loose? Which sounds possible to me...
Jason Banks is offline   Reply With Quote
Old 04-21-2018, 09:48 PM   #3
OARNGESI
OARNGESI's Avatar
It’s fine when you put the truck on the ground it’ll stay put
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 04-21-2018, 09:50 PM   #4
Dodge68charger
New Springs Are Loose. I'll Try and Put it on The Ground andSee What Happens. ThanksGuys
Old 04-21-2018, 09:52 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Once the suspension compresses to ride height... they'll tighten up.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-21-2018, 11:19 PM   #6
Dodge68charger
Now that The suspensions Compressed it Tightend Up... Dam Its Low With Drop Spindles
Old 04-22-2018, 03:10 AM   #7
OARNGESI
OARNGESI's Avatar
Wait till it settles it may drop more after a bit of driving
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 04-22-2018, 08:35 AM   #8
hewittca
hewittca's Avatar
That's normal for 3-4" drop springs. I have 3.5" springs in mine and they are completely fine when the truck is on the ground. The only PITA is making sure they reseat properly whenever you're letting the truck back down on the ground.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 | Oscar the 70 C10
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 04-22-2018, 02:11 PM   #9
Dodge68charger
Thanks Guys. Now Gotta Get The Back To Match
