Old 04-21-2018, 10:45 PM   #1
Robznob11
Robznob11's Avatar
I need some help with a 65 c20 interchange please.
Ok so I found out that the 65 c20 uses the 5/8 threads on tierod like the c10. But it appears that the taper is larger. Is it the same taper as the 71-72 half ton. My issue is that I have custom conversion adjusters that use a 5/8 thread, but I just realized someone has changed the draglink ti a 71/72 c10 that takes the larger tie rod. Anyone have specs on a es358L tie rod?
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
