04-22-2018, 07:40 AM | #1 |
FS stock height spindles powder coated & almost new
I got these in a deal with tubular control arms that had 71-72 ball joints in them I decided to use lowering spindles instead of these
PO said they had 1500 miles on them and he converted to a coil-over suspension Here is the info from Western Chassis they verifyied that the are 1973-87 Chevy C10 Stock Height Replacement Spindles Replacement spindles for 73-87 Chevy C10, GMC C15 or Suburban. Great for disc brake conversions using late model front end on an early truck. $239.00 new from Western chassis I put Keith Lolife99 write up on conversions below I believe you can use these on 67 -69 if you want to convert if you change ball joints and tie rod ends depending on the year you are converting I would like to get $80.00 for the pair plus shipping and PP fees or a USPSMO Lolife 99 write up on conversions Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
04-27-2018, 10:36 AM | #2 |
Re: FS stock height spindles powder coated & almost new
Top
