Old 04-22-2018, 08:28 PM   #1
otter5555
weird ac question
i installed a new underdash ac unit in my old chevy truck
bought it on ebay
it has the sanden compressor
for 2 months it worked perfectly, blew 22 degree air, cycled perfectly
then it started freezing up even with the thermostat turned to 0
i suspected low freon but pressures were perfect
i went ahead and removed the freon , pulled a vaccum and put the exact amount specified in again. same thing freeze up in 15 minutes
i bought a whole new evaparator and installed it. freeze up in 15 minutes
i bought a new compressor. same thing. freeze up in 15 minutes.
i pulled belt off of the compressor. freeze up in 15 minutes.
so, here we are. not even a belt on the compressor. 15 minutes driving down the road @ 45 mph and the evaperator is a solid chunk of ice.
i recently made an 8 hr trip and it stayed frozen the whole way.
any ideas?
thanks in advance
otter5555 is offline   Reply With Quote
Old 04-22-2018, 08:41 PM   #2
Bandit130
Bandit130's Avatar
Re: weird ac question
Welcome to the site.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 04-22-2018, 09:08 PM   #3
v30crewcab
v30crewcab's Avatar
need to adjust your low pressure switch, or the expansion valve is hanging up and needs to be replaced.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 04-22-2018, 09:09 PM   #4
otter5555
replaced both already but thanks
every part of the system has been replaced 2x except the hoses
i dont even have a belt on the compressor and it freezes up
Old 04-22-2018, 09:26 PM   #5
v30crewcab
v30crewcab's Avatar
I've had to adjust many low pressure switches right out of the box. do you have gauges you can hook up and read the low pressure side?
how could it possibly freeze up with no belt on it? no spinning no pressure??????
71 longbed 5.3 4l80
Old 04-22-2018, 09:29 PM   #6
otter5555
that's my whole point. the compressor has no belt on it. i took it off . the compressor is not turning at all.
in 15 minutes driving 45 mph it freezes solid and stays frozen till you kill the engine
Old 04-22-2018, 11:18 PM   #7
SunSoaked
SunSoaked's Avatar
So your saying the evaporator is freezing solid-temperature wise- without the compressor operating? Impossible.
How do you know this, is the evap removed from it's housing? Do you lose airflow thru the vents? If so, maybe a fan blower issue, but no way is the evap freezing up without gas flowing in the system.
SunSoaked is offline   Reply With Quote
Old 04-23-2018, 07:17 AM   #8
70GMCer
70GMCer's Avatar
Freezing without the compressor connected ?? IMPOSSIBLE !!!
Freon is a gas within the system until it is compressed to a liquid.
If you are getting ice, then it is because you either have a blockage within the system, dirty evap or condenser. But, again, no icing without the compressor running...
When the system is iced up, the low pressure reading with be very low on the gauge.
I'm just wondering if this poster is just seeing what comments will be made on this subject. Wanting a laugh....just saying....
70GMCer is offline   Reply With Quote
Old 04-23-2018, 08:31 AM   #9
otter5555
not hardly. this has been going on since oct 2017. i've tried everything. what is happening can't happen....but it is.
Old 04-23-2018, 08:39 AM   #10
Wgesnerjr
Wgesnerjr's Avatar
Seeing is believing.
Got pictures?
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 04-23-2018, 12:49 PM   #11
truckin 79
If vents are shooting out 22 degree temps that is a freezer unit not a AC unit. Take it to a AC place, I have found places that charge as low as 66 plus whatever freon they use.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 04-23-2018, 03:59 PM   #12
tucsonjwt
x2 on take it to a pro. Make sure it is a shop that does only A/C, not jack of all trades mechanic.
I personally am skeptical of aftermarket A/C systems, but Sanden is highly recommended by the local A/C shop I use, so I don't think you have a compressor problem. When I finally get the compressor replaced on my old 83 I think I will go with an Alma Products new A6 because I don't like the cheap looking adapter brackets I would have to use to convert to Sanden.
tucsonjwt is offline   Reply With Quote
Old 04-23-2018, 05:25 PM   #13
Dayton601
Dayton601's Avatar
Take a picture of your set up, and show us were its freezing up,
Dayton601 is offline   Reply With Quote
Old 04-23-2018, 07:11 PM   #14
jkk
jkk's Avatar
No compressor running I say BS on the freezing up part.....!
jkk is offline   Reply With Quote
Old 04-25-2018, 11:43 AM   #15
hatzie
Moderator
hatzie's Avatar
Basic Principles of Refrigeration
Liquids absorb heat when changed from liquid to gas
Gases give off heat when changed from gas to liquid.
For an air conditioning system to operate with economy, the refrigerant must be used repeatedly. For this reason, all air conditioners use the same cycle of compression, condensation, expansion, and evaporation in a closed circuit. The same refrigerant is used to move the heat from one area, to cool this area, and to expel this heat in another area.
The refrigerant comes into the compressor as a low-pressure gas, it is compressed and then moves out of the compressor as a high-pressure gas.
The gas then flows to the condenser. Here the gas condenses to a liquid, and gives off its heat to the outside air.
The liquid then moves to the expansion valve under high pressure. This valve restricts the flow of the fluid, and lowers its pressure as it leaves the expansion valve.
The low-pressure liquid then moves to the evaporator, where heat from the inside air is absorbed and changes it from a liquid to a gas.
As a hot low-pressure gas, the refrigerant moves to the compressor where the entire cycle is repeated.
Note that the four-part cycle is divided at the center into a high side and a low side This refers to the pressures of the refrigerant in each side of the system
TANSTAAFL... If the belt is off the compressor then there's no cooling at all.
The compressor has to compress the refrigerant or there's no refrigerant state change to liquid at the condenser and back to gas at the evaporator.
No state change = no cooling. End of story.
I assume the evaporator froze up and you expected the block of ice to thaw quickly when you pulled the belt. Nope. Ain't gonna happen. Once it's frozen solid there's no airflow through the evaporator. It could take several hours to thaw even on a good hot day.
Don't believe me? Set a 6" x 3" x 12" solid block of ice in the shade. You may be shocked how long it takes to thaw even on a relatively hot day. The evaporator box is mildly insulated. It could take a very long time to thaw out.
You are not getting 22°F out of the vents. 22°C (71°F) I can believe... 35°F vent temps are possible but too low as the evaporator will be below the frost temp of 32°F or 0°C. You want vent temps in the 40-45°F range with outdoor ambient of around 85°F... without driving the high side pressure into the stratosphere when the outdoor ambient temps climb into the 100°F area.
A freezing evaporator is either a low refrigerant charge or restricted airflow. Intake to the blower? Mice or leaves or...
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-25-2018, 12:34 PM   #16
SunSoaked
SunSoaked's Avatar
Well said hatzie.
Stick a fork in this thread!
Old 04-25-2018, 02:05 PM   #17
Jeepwm69
I have an R4 on both the 83 and the 95.
From what I've seen the A6's aren't all that great either.
Where does one get adapter brackets to use a Sanden?
Jeepwm69 is offline   Reply With Quote
Old 04-25-2018, 06:31 PM   #18
tucsonjwt
I have had several vehicles with A6 compressors and they put out a massive amount of cold air - when they were working properly. The problem with them is that they shoot out copious amounts of oil. Alma Products claims to have fixed that problem. Of course, they do suck some horsepower and penalize mpg, but if you own a 454 you have already given up on fuel economy.
A6 compressors are still used in new heavy equipment (dozers, excavators, etc.) so somebody still thinks they have a purpose.
There are several places to get Sanden adapters for 454s, but I have had trouble keeping the belt quiet with my heavy one piece steel factory bracket, so I don't think the two piece sheet metal adapters would be very steady. They look like something I would make with tin snips and a jig saw in my backyard. This is what they look like.
https://www.speedwaymotors.com/Vinta...vy,256916.html
https://www.summitracing.com/parts/b...make/chevrolet
https://www.speedwaymotors.com/shop/...10-4-461-14796
There is another option - the lightweight S6 compressor, which the local A/C shops around here will not install because of no history with this compressor. I have read some bad reviews on it. It appears to be just an A6 in a lightweight housing, and they are not cheap, so I think I would prefer a new Alma A6.
BTW, my local A/C shop told me my DIY Geo Metro pusher fan which works when the compressor turns on does nothing to help the A/C perform better. He said it did no harm but did no good either. I guess his idea is that it is not necessary with a properly performing system, and I would agree, since I have had several A6 systems which did not need any supplemental help.
Old 04-26-2018, 02:00 PM   #19
Jeepwm69
I've got a 305 in mine. The A6 might keep it from going anywhere LOL.
I have Sandens on my AMC era Jeeps. That was the stock setup on the CJ's.
