Old 04-23-2018, 11:03 AM   #1
70inbville
Front clip exchange
Will a complete clip from a mid 80’s bolt up on a 74 cab and frame?
70inbville is offline   Reply With Quote
Old 04-23-2018, 12:12 PM   #2
Cherub
Cherub's Avatar
Re: Front clip exchange
front frame and core support mounts are different
Cherub is offline   Reply With Quote
Old 04-23-2018, 12:15 PM   #3
70inbville
How ar off are they. Is it something that can be modded easily or not worth the time and thank you for the fast response!
Old 04-23-2018, 01:35 PM   #4
Tiger Joe
80s hoods have the upper hinges that bolt to cowl, wheres as 79 and older have the hinges bolted only to the fender.
I've done the opposite- 79 clip on 87 front end with no issue. but like I said not sure about the hinges
Tiger Joe is offline   Reply With Quote
Old 04-24-2018, 01:22 AM   #5
esbstuff
Mostly yes. The bumper brackets need modded some (no frame cutting!) to fit. Overall a easy swap.
Check/search here to find more info. Its been discussed in length before.
This is a good link for the clip swap with the exception of the frame/core support mounts and front bumper...
http://67-72chevytrucks.com/vboard/s...ront+clip+swap
I never had to move the frame mounts, I just used the right rubber bushings for what I was doing....
Here is a link for the front bumper mounts... Look at reply #15 for bumper bracket instructions.
http://67-72chevytrucks.com/vboard/s...d.php?t=514024
esbstuff is offline   Reply With Quote
Old 04-24-2018, 07:02 AM   #6
70inbville
Thank you
