Old 04-23-2018, 07:23 PM   #1
NJKelly
Stock or lifted?
I've had a couple of mechanics and other Auto enthusiasts look at my truck and half believe it has a lift kit while the others believe it may be stock. I'm hoping that with the pictures attached someone can give me a definitive answer, I'd like it to be stock with no lift and 31s but if I cannot take lift out I'll go with 33s, thank you.
NJKelly is offline   Reply With Quote
Old 04-23-2018, 08:01 PM   #2
NJKelly
Re: Stock or lifted?
Can't upload pics, still trying to figure this out.
Old 04-23-2018, 08:18 PM   #3
NJKelly
http://67-72chevytrucks.com/gallery/...&ppuser=182579
Hope this works
Old 04-23-2018, 08:40 PM   #4
A1971Blazer
A1971Blazer's Avatar
Lifted...for sure......the factory front springs have a negative arch...in other words they're almost flat or slightly arched upward....also the tall block on the rear axle.....
is a dead giveaway
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 04-23-2018, 08:46 PM   #5
jaros44sr
jaros44sr's Avatar
is a dead giveaway
I agree, it looks to a 4" lift.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-23-2018, 09:16 PM   #6
NJKelly
Thanks for the quick responses. Now I have to research how to get it back to stock, but I prefer the way the stock
sit lower, easier to get in and out of.
Old 04-23-2018, 09:49 PM   #7
NJKelly
So I look at a rough country 4 inch lift kit and it seems there's the rear springs blocks and then u bolts as well as shocks, nothing in the way of front spring swap out. I imagine that if I just get new shocks and four new Springs and the bushings and u Bolts Etc I could bring this back to stock. Am I over simplifying this, any tips. Thanks guys.
Old 04-23-2018, 10:21 PM   #8
Spf79
Spf79's Avatar
Maybe put a 2" lift on it and run 33's? That setup gives it a real nice stance.
Do you know if your steering arm is stock or is it an aftermarket raised arm?
Are you looking to replace shocks right now as well?
Full top blazer or bust....
Spf79 is offline   Reply With Quote
Old 04-23-2018, 11:05 PM   #9
NJKelly
Not sure if steering arm is original or not. I've been pricing out the parts to bring it back to stock and I might be better off just getting new rims and tires 33's or 35s, it would be cheaper and if I were to sell it most people would want it lifted I would think.
Old 04-23-2018, 11:07 PM   #10
Spf79
Spf79's Avatar
I would agree with you on that.
Old 04-24-2018, 01:13 AM   #11
simicrintz
Mine is completely stock; wish it had a slight lift (2-4 inches); would look so much better! Do not be afraid of the lift!
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 04-24-2018, 10:16 AM   #12
NJKelly
I wonder if I was to drop the lift from 4 in to 2 in if it would require less Parts. Maybe the same Springs with a 2-inch block and different Springs up-front, is there any way to identify who the manufacturer is of the springs, softride, Rough Country or others.
Old 04-24-2018, 03:09 PM   #13
SeventyOne
New rims and tires will cost you way more than new front springs and shocks id think...
Rear: you just need to remove the blocks. If you have a 4" lift, and the block is 4"...the springs are fine. Get new ubolts and be done.
Front: new springs. could maybe reuse the ubolts since the spring pack in new leaves would be slightly thinner.
Then stock height shocks.
IF you want to go from 4" to 2" lift I would buy a new complete 2" lift and then sell this 4" lift to recoup costs rather than piecing stuff together. I'd guess the lift will sell fast.
SeventyOne is offline   Reply With Quote
Old 04-24-2018, 03:22 PM   #14
A1971Blazer
My '70 had a 4" BDS lift on it with 35x12.50 tires when I bought it......it's more like 6"...it's too high and too bouncy for my liking....I bought a complete Tuff Country 2½" kit that I will be installing at the same time I do the LS1 swap..new springs front and rear with gas charged shocks.... have a front sway bar that will be going on as well....along with 33x12.50 tires...
1967 C10 Step side
1968 C10 Step side
Old 04-24-2018, 04:06 PM   #15
cori 64
cori 64's Avatar
This is how mine sits with a tuff country 2" lift and the blocks removed in the back...still don't know what lift i had .. front springs were done and the blocks were 3"...tires are 33/10.5/15 bfg km2
cori 64 is offline   Reply With Quote
Old 04-24-2018, 05:41 PM   #16
NJKelly
I'm buying new tires regardless, it just a question of what size. The rims are steelies that are beat up but could be cleaned up with a little sandpaper and paint. This is going to be a no fuss no muss kind of a truck not a show truck. However I don't want it to be embarrassing sitting in front of the house. When you say new shocks you mean all the way around correct, not just the front. The springs that you see in the picture on the back with the 4-inch lift I could leave on once I remove that block, it wouldn't be stock but close enough ......
Old 04-24-2018, 05:42 PM   #17
NJKelly
Love to see that from further away so I can get a better idea of how that size tire looks.
Old 04-24-2018, 09:11 PM   #18
SeventyOne
isnt that block in back 4"? Usually in 4" lifts the front is a new spring and the back (for cheaper lift options) its a block. My guess is the rear springs are stock unless you have reason to think otherwise.
Old 04-24-2018, 10:51 PM   #19
NJKelly
Ahhh, that's why the lift kits I see only have two springs. I assumed they were the back springs.
Old 04-25-2018, 12:04 PM   #20
SeventyOne
Yes - some manufacturers though will let you buy a more expensive version with replacement rear springs. Honestly though with our reverse shackle rear setup the block probably gives a better ride versus a more highly arched spring. Depends what you want out of your K5.
For me - I went with a shackle flip
Old 04-25-2018, 12:43 PM   #21
NJKelly
Shackle flip???
Old 04-25-2018, 01:14 PM   #22
SeventyOne
http://www.offroaddesign.com/catalog/shacklekit.htm
My guess is this isn't something you'd want to do but it is an option.
Old 04-25-2018, 08:07 PM   #23
NJKelly
Probably not, i really like the look of the stock original K5's, like a station wagon on steroids. Really appreciate your taking the time to educate me on this subject, knowledge is power, or something like that
