Short water pump for 5.7 vortec.
I want to put a short water pump on a new 5.7 vortec that i'm gonna put in my 72 C20. The parts guy at gm said any short water pump would work, but i'm skeptical with the plastic timing chain cover a lot of people had fitment issues that I see online about having to change out or shave some bolts. I just want somthing that will bolt on without issues and will work with my original v belt pulleys that I want to use. I found one water pump that claims it is designed to fit over the cover its the https://www.summitracing.com/parts/edl-8810/overview/. A little expensive but if its made to fit then it might be worth it. The parts guy at GM showed me this waterpump and told me it would fit. https://www.summitracing.com/parts/nal-19168604 I see they are different pilot diameters too, can someone explain what the piliot diameter is and what one i will need for using orignal v belt pullies from a 72 350 and a standard rotation water pump on a newer 5.7 vortec (l31-r)? One guy in the revews of the gm water pump said their are two different lengths of short water pumps and that one is the longer one? I'm not sure what one would be the right application or what the short one even is. The parts guy was also pretty sure that my orignal manifolds would not fit even though some members on the board said they will. Any input on that? Thanks
Re: Short water pump for 5.7 vortec.
The larger pilot is for the Corvette pulleys and fan clutch. Just buy a pump for the year vehicle you are using the pulleys and fan assembly from. If the motor is out, why not put all new gaskets in it while you can along with a stamped steel timing cover and not have to worry about it.
![]() Join Date: Oct 2009
Pilot dia is the width of the nub that the pulley centers on. Vortec intake manifold is required to ensure a good seal - bolts are vertical, not canted like original. As for the timing cover - I’m with mike, replace with stock steel and call it a day.
Have never heard of two different lengths of short pumps, curious to hear where this goes. I’m interested in the same conversion you’re doing, and am learning there are a few nuances of which to be aware. Also note that there is no mech fuel pump boss on a L31R, you’ll need an electric one. None of the little issues are insurmountable, many folks have already done this swap with no issues. Personally, I’m on the fence between the L31R and an HT383 ($ being the primary decider... ha) |
Thanks for some insight. I was talking about the exhaust manifolds not the intake sorry should have clarified. I have all my stock pulleys/belt I want to use them with the new engine. I’m either gonna go with the Edelbrock or get one from Napa and buy a stamped cover. Anyone know if the Edelbrock 8810 is the same pilot diameter as the stock water pump for 72 c20 but it’s just made to fit over the plastic timing chain cover? I can measure the old water pump too when I get home. Thanks
OE rams horns will fit the L31.
Forgot to post pic! (These are 2.5 vette manifolds)
I've done the swap using a Vortech 5.7 from a 1999 suburban. I used long style water pump and Accessories drives on mine so I can't help you there. If someone makes a stamped steel timing cover for this application I'm unaware of it. The plastic timing cover on the Vortec is completely different and will not interchange with the old style stamped steel small block timing cover. The cylinder head uses a metric fitting where the temp sender would be installed. You will need an adapter for that to run a stock temp sender. I did not run stock exhaust manifolds but something to check while the engine is out: Bolt on the exhaust manifolds and check for clearance around the spark plugs. The spark plug placement is different and makes it very tight in spots. I had to modify my headers slightly for this. You'll be very happy with the upgrade of this engine, makes a tremendous difference over the stock 350.
Steve weim55 Colorado |
Something else I noticed in BW s pictures, check for clearance for the passenger side dipstick, the flywheel pattern is different to at the crank, you will need to replace that too.
Thanks for the clarification Chilly - sorry, yes, exh manifolds fit (good pics BW). Steve - helpful info, thank you from me also - was not aware the timing cover was not interchangeable.
Interesting.
#11 | |
As far as the temp sending hole in the cylinder head, the hole is S.A.E. thread and a standard pipe plug or sending unit adapter will fit, although the diameter of the hole is smaller on the vortec heads compared to old style GM iron heads. |
Or you can just run the sending unit in the intake like I plan to do.
#13 |
Personally i prefer the sender in the head - member BrianMac has, at least in the past, turned down a few stock senders and re-threaded for me to fit the smaller opening, might be worth asking.
#14 | |
I really wanted to run the stock steel Cover and balancer so I would have a proper matched timing Mark and timing tab for use with a timing light in my carbureted HEI application. I degreed The Vortech balancer myself for use with the timing mark on the plastic timing cover. It's visible between the long water pump and the cover with a timing light. With a short water pump this mark is completely covered and unusable. To use the original stock steel cover and timing tab would really help as it's designed to be visible with your short style accessory drive set up. Steve weim55 Colorado |
#15 |
Scrapper 1
I'm using a 1997 Vortex 350 engine.But put the stock Heads back on the roller motor the Vortex heads suck they like to crack.Ya i don't get as good of mileage.But there better heads.I had no problem using the old Timing cover for my 1997.The real problem is finding that long dip stick tube and inner peace for not spending 80.00.Found one for 40.00I run all the stock stuff off my 1972 chevy truck on my roller motor
#16 |
I've never, ever heard that. The main advantage of a Vortec swap IS the heads. Interesting - not disputing, just have never heard of this. Any more info? Stock heads on a Vortec short block would be a pretty low compression combo I'd think.
#17 |
So I got the block today and my water pump doesn't clear unsurprisingly. Seems like it is hitting one bolt for the timing chain cover on the left side. Does anyone have a link to a bolt for this that has a shorter head? If I use the same water pump and v belt brackets will my pulleys line up on this new block? If I go with the Edelbrock 8810 will the overall length be longer so that it can clear the cover but would be belt even line up then? Not sure if I want to spend the 230 on the pump or try shaving or changing out that bolt.
#18 |
Well, I can't answer your question - but I would not think the Edelbrock pump pulley mount flange would be any different from stock or anyone who put it on an old block would have alignment issues. I would have to assume the extra timing cover clearance would have been carved out by slimming down the backside where it clears the cover without sacrificing final pulley centerline. That would be bad fer business...
#19 | |
Like any engine, if it was abused and not maintained it's more likely to be in poor condition compared to one that was pampered. With that said I've used a few Vortec headed engine in excess of 200,00 miles and the heads and block were fine. |
#20 |
I'm trying to visualize where all the cooling hoses will route with this new engine. I have the edelbrock 2716 intake. https://www.summitracing.com/parts/edl-2716/overview/
I don't have power steering or ac and I plan on using the v belt pulley and old water pump. So to my understanding the upper radiator hose goes to the thermostat, then the lower goes to the bottom of the water pump. Then for the coolant bypass a hose would go from the coolant bypass port on the front of the intake before the thermostat to the top of the heater core then to the bottom of the heater core to the top of the water pump. Then that's it. Is this right? Is there a difference if I ran the bypass from the angled port on the left of the top front of the intake instead of running it from the front port? Can coolant still go the the left port when the thermostat is closed? I'm assuming I can use the right port for the temp sending unit. What would be the rest of the port for? I'm thinking of doing it like post 13, although I don't know what the H thing he is running is for in the second image. http://67-72chevytrucks.com/vboard/s...d.php?t=593209 Last edited by Chilly178; 04-28-2018 at 08:57 PM. |
