Old 04-24-2018, 11:22 AM   #1
demian5
demian5's Avatar
CPP Combo Valve-to-stock brake line adapter fittings
Ok, I need help from the guys who have done this before.
Doing my disc brake conversion, using a CPP combo valve and my stock brake lines, the front brake line appears to be larger than the hole in the combo valve, and the rear appears to be smaller.
I figured Im looking for:
Front: 3/8" x 24 male inverted flare to a 7/16" x 24 female inverted flare
Rear: 9/16" x 20 male inverted flare to a 1/2" x 18 female inverted flare
Sound right?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 04-24-2018, 12:35 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: CPP Combo Valve-to-stock fuel line adapter fittings
Cpp should have the necessary adapters. When I did mine they sold a package containing 3 different ones. They were the only place I could find the proper sizes, no auto parts store or fastener shop had the proper size.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 04-24-2018, 12:55 PM   #3
cleszkie
cleszkie's Avatar
I seem to recall my CPP combo valve coming with the set of adapter fittings.
cleszkie is offline   Reply With Quote
Old 04-24-2018, 01:47 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
My stock brake lines matched right up to the CPP combo valve. But my rig is a 1972... so that might have had something to do with it.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-24-2018, 01:50 PM   #5
demian5
demian5's Avatar
Found on the site.
PROP VALVE FITTINGS
CP2091 9/16"-18 inverted male flare, 3/8"-24, 7/16"-24, 1/2"-20 inverted female, kit $10.00
Pretty much what I thought. Ill cruise to a hardware place and get them.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 04-24-2018, 01:59 PM   #6
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by demian5 View Post
Found on the site.
PROP VALVE FITTINGS
That’s the one. Good luck finding them anywhere else. I even went to McFadden/Dale, which carries everything under the sun...and they didn’t even have them.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-24-2018, 02:42 PM   #7
demian5
demian5's Avatar
How long ago for McFadden Dale?
Grainger next door says they have them on the website. I actually found them at Autozone last night but didn't like the fit.
Worse case im driving to CPP at lunch tomorrow to get the set.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 04-25-2018, 05:57 PM   #8
demian5
demian5's Avatar
Drove to CPP they had the adapter in a set of 3 (for 3 different sizes) for the rear brake line (it is steel). The front I had to source myself, and it is brass from Pep Boys.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 04-26-2018, 06:17 PM   #9
demian5
demian5's Avatar
Got it installed, now on to the ball joints before the installation of the brackets and the brakes.
1986 C20 Scottsdale
Instagram: C10sofOC
