Old 04-24-2018, 11:32 AM   #1
indianpride77
indianpride77's Avatar
fuel tank relocation
So i am trying to figure out the best way to do this. i have a 76 c10 fleetside that i am going to buy the k5 blazer tank and relocate it to the rear. I'm hoping for help with two things. one does anyone have pics of theirs installed? i'm trying to figure out the best way to mount it. secondly i am going to be installing a rear 4 link and airbags. would it be best to wait until those are installed before installing the tank??
indianpride77 is offline   Reply With Quote
Old 04-24-2018, 12:03 PM   #2
tinydb84
tinydb84's Avatar
Re: fuel tank relocation
Definitely install your 4 link first. The tank is pretty large so you want to make sure you have enough space and ground clearance. I have a blazer tank swapped in mine but I did a new backhalf so the pics wont be too much help.
David
Instagram: myfabguy
Old 08-19-2019, 07:18 PM   #3
kidatheart
kidatheart's Avatar
I am wanting to do the same type of relocation-either blazer or suburban tank. Did you ever get yours done?
kidatheart is offline   Reply With Quote
Old 08-21-2019, 07:09 PM   #4
thrtsxchambers
thrtsxchambers's Avatar
Pretty old post but here is how I did mine. Basically sits in stock location as a blazer or suburban. I removed the rear brace and moved it to the end of the frame. Mine is bagged , I mounted tank inside the frame instead of under the frame just to help ground clearance. Full laid out the tank is about 2.5 inches off the ground. At ride height it is about 5-6 inches off the ground. not the greatest picture but only one I have on my laptop.
thrtsxchambers is offline   Reply With Quote
Old 08-27-2019, 03:40 PM   #5
Loco83
Loco83's Avatar
What is the capacity of those blazer tanks?
Loco83 is offline   Reply With Quote
Old 08-27-2019, 07:25 PM   #6
Bloodhound
You can get 25 or 31 gallon.
Bloodhound is offline   Reply With Quote
Old 08-30-2019, 12:02 AM   #7
Ziegelsteinfaust
Another option if you do not need the capacity is use a Mustang tank. They are smaller, and will give you some extra ground clearance if you need it.
The hardest part is converting the ohm sender to gm values.
Ziegelsteinfaust is offline   Reply With Quote
