Old 04-24-2018, 01:33 PM   #1
Kinger615
Bigger ball joints ?????
My lower ball joint on my 63 fits a little loose.Dowa Anybody know who might sell a oversized one? I called Moog and they have nothing. Anybody else having this issue ?
Kinger615 is offline   Reply With Quote
Old 04-24-2018, 11:37 PM   #2
Captainfab
60-66 Nut
Re: Bigger ball joints ?????
Is it loose in the spindle or in the lower control arm? I think you will just have to replace the part that is worn.
Old 04-25-2018, 06:33 AM   #3
bonehead
bonehead's Avatar
if the ball joint socket is not worn beyond repair, you might be able to re-ream the taper so the joint just sits slightly lower, but solidly, in the tapered socket.
This would only work for minor damage to the taper. FWIW
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
bonehead is offline   Reply With Quote
Old 04-25-2018, 07:34 AM   #4
On my old 70, I put a few tack welds in the a-arm area, then smoothed them out and it basically rebuilt the taper area and the ball joint fit in the socket hole tightly again.
Old 04-27-2018, 10:08 PM   #5
dodgiesdad
dodgiesdad's Avatar
I had off-road truck I had to gusset the socket on the upper A arm and tack weld the ball-joint into. With out doing that I kept blowing the joint out on landings.
dodgiesdad is offline   Reply With Quote
Old 04-27-2018, 10:18 PM   #6
rvrfoot
Do you have any pictures?
rvrfoot is offline   Reply With Quote
