Old 11-10-2003, 09:12 PM   #1
frisky68
"Shocking" question
I have been getting a shock everytime I get out of my truck...I can touch any metal surface inside the truck, and nothing...but as soon as I close the door and touch the outside of the truck...zap....happens to the passenger as well...is this a grounding issue ??
94 K1500 SWB w/ 4" body and suspension lift
frisky68 is offline   Reply With Quote
Old 11-10-2003, 09:15 PM   #2
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
I have grounding straps inside my engine compartment that are daisy chained to everything in the compartment and grounded to the frame!! I am not sure if this is stock, I think so though.
I have never received a shock off my truck yet, but always do on others!!!
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 11-10-2003, 09:29 PM   #3
gonebad2
Merciless Butcher
gonebad2's Avatar
GM originally put grounding straps in several different spots. The one usually missing is the one next to the right front cab mount. Alot of people remove these when they do a frame off and don't put them back on. You can't rely on the engine mounts for a ground.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 11-10-2003, 09:31 PM   #4
lukecp
Formerly yellow72custom
lukecp's Avatar
Are you sure that it just isn't static electricity?
If not...i would say you have a wire shorting out somehwere.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 11-10-2003, 09:41 PM   #5
frisky68
I'm thinking it is static electricity, but what do I need to do to get rid of it...I have seen the older cars that drag a small strip of rubber to help eliminate this, but would prefer not to go that route
Old 11-10-2003, 10:03 PM   #6
oldtrucknut
67-72 truck surgeon
Get used to it kid. The only way to eliminate that is to grease your seat so you don't create friction. It usually only happens to me in the winter when the air is dry.
1969 Chevy C10
1993 Toyota Camry LE
1999 Ford F250 Super Duty 4x4 diesel
2008 Dodge Charger Super Bee
1953 International R182
oldtrucknut is offline   Reply With Quote
Old 11-10-2003, 10:12 PM   #7
jef5150
Inline 69
jef5150's Avatar
heres a couple things u can do
DONT LAUGH !!!BUT,,,All you have to do is hang on the car when you get out,"something metal",then you put your feet down and that way you discharge yourself into the car. No shock. #2..you can spray the seats and the floor mat with
static guard.,,,,....#3... Or you can put lambskin seat covers on your car which keeps you from building up a static charge in the first place,,,,,,, JEFF http://www.nbc4.com/tricksofthetrade...75/detail.html
jef5150 is offline   Reply With Quote
Old 11-10-2003, 10:21 PM   #8
oldtrucknut
67-72 truck surgeon
Good points Jeff.
1969 Chevy C10
Old 11-10-2003, 10:30 PM   #9
cdowns
cdowns's Avatar
if you stop wearing pantyhose the static electricity won't be that great
Old 11-10-2003, 10:39 PM   #10
walker
walker's Avatar
My wifes car used to have that problem and it is pretty common on some cars. It had something to do with the rubber the tires were made out of. It seems that the high milage hard rubber tires would promote static that couldn't ground. When we changed tires we went with a different brand and the problem with away. I have also heard you can spray your car with laundry type static guard.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 11-10-2003, 11:08 PM   #11
Randy70C-10
Randy70C-10's Avatar
But I use "Cling Free" in the dryer.
Randy70C-10 is offline   Reply With Quote
Old 11-10-2003, 11:21 PM   #12
jef5150
Inline 69
jef5150's Avatar
CDOWNS---(if you stop wearing pantyhose the static electricity won't be that great).....I.L.M.F.A.O,, ,,,,(STILL LAUGHING AS I TYPE)......JEFF
Old 11-11-2003, 12:26 AM   #13
cdowns
cdowns's Avatar
aside from the pantyhose thing, what happens up north in the winter is you're wearing coats with alot of nylon in them and that causes alot of static electricity especially if you have leather soled shoes, putting the coat in the dryer for 1/2 hour with cling-free will help somewhat as well as rubber-soled boots or shoes, also rubber floormats and holding the metal frame of the door when getting out helps too
i solved the problem by moving to florida and in shorts and t-shirts don't have static problems
