NAPA Ignition Switch Fail !
I bought a replacement ignition switch assembly from NAPA for my 71 GMC. First one would not slide into the spacer used to secure it into the dash, Basel also would not screw onto the threaded end of the housing. Returned it and tried another one only to have same issue. Box stated made in Tiawan...just a heads up !
71 C-20 07 Magnum RT AWD |
![]() Join Date: Jan 2003
Re: NAPA Ignition Switch Fail !
okay.
1969 307, t3501950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
I swapped out my OEM ignition switch years ago with a repop unit. The repop sucked and ended up having issues. I ended up finding a used OEM unit to stick back in there. Its been working great for over a decade now. Something to be said for the OEM stuff, even if it is used. This goes for the reverse switch on the steering column too.
![]() Join Date: Apr 2016
I had a similar experience just last month. Bought a new ignition switch from Rock Auto. ACDelco brand. I had to file a bit from the switch body to get it to fit into the spacer. Seemed like the 3 tangs were off just a little. The bezel did screw on however. I am beginning to lose confidence in ACDelco quality.
1972 GMC K2500 Super Custom Matt |
laying low
![]() Join Date: Mar 2001
I recently bought a window switch from rock auto for a cadillac. It said AC Delco but it also said made in Taiwan. It didn't fit....
That is the 2nd AC Delco switch I've had a problem with in the last couple of years.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver 'primer is finer' Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
All about them K’s
![]() Join Date: Jun 2014
Most ac Delco branded stuff any more is just re packaged aftermarket junk. There’s plenty of reading here and on other sites about this very topic. It’s Pretty disappointing.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
| Bookmarks |
