Old 04-26-2018, 06:23 PM   #1
Robert Haas
Complete rewire using American Auto Wire kit for 1960 to 1966 C10/20/30
Step by step tutorial on rewiring our truck. My truck is not stock but this process is identical to how you will do this and with this specific kit it is mostly plug and play.
So first thing is the unboxing and exploration of the kit. A couple notes
Kit is packaged in an intuitive and intelligent manner with separate packaging for different parts of the truck. The under-hood kit is not in with the lighting. The acc. wiring is separate as some of our trucks don't have any of that, the engine harness is separated from the front half lighting.
here is the new stuff. I laid it out upside down so you can see the stuff in the bags. On the top of each bag is a label and description of what is inside.
Name:  autowire laid out.jpg
Name:  close up of kit.jpg
I laid out the tools I will need to do the install.
Name:  hand tools.jpg
Name:  multi meter and power probe.jpg
So with no more excuses to delay, I pulled the seat out of the truck and got ready to make my back hurt
Name:  seat out ready to start.jpg
Robert Haas is offline   Reply With Quote
Old 04-26-2018, 06:38 PM   #2
Pinchecharlie
Re: Complete rewire using American Auto Wire kit for 1960 to 1966 C10/20/30
You da man!!!
Pinchecharlie is offline   Reply With Quote
Old 04-26-2018, 06:49 PM   #3
Robert Haas
So Pulled the old carpet and padding out. Took my time to not tear it as it was glued down 25 years ago. It was still in good shape and will have to live a couple more years before I do yet another chassis up build.
Here it is with the carpet out.
I have owned this truck for ever. in that time it has had 3 different stereos installed as well as an alarm system. A new column and several different sets of gauges. None of that was done by me. (Well the column was mine but I kind of cobbed it in too. So the amount of splices, and old dead wires with the ubiquitous electrical tape and zip ties made this truck about as reliable as a meth addict.
see for your self.
here is the instrument panel before I pulled it out. All nice guages and I did do a pretty decent job wiring it all in but it is wired into the original 53 year old harness.
Name:  instrument panel before demo.jpg
Old 04-26-2018, 07:02 PM   #4
Robert Haas
Continuing with the demolition.
a couple notes here. Last year I did a head light up grade with new halo LED's with High output LED projectors. I built a new harness and used new OEM plugs tied into the front harness so I need to incorporate that harness into the new Autowire kit. This holds true for the trucks current (4th) stereo as I installed it and did it correctly so it to will be incorporated.
So this is the back of the instrument panel and probably has the most complicated part of this. For the folks with a stock truck this is all plug in with the new harness.
Name:  back of instruments.jpg
this is looking in at the rats nest once the instrument panel is out.
Name:  instruments out old wires shown.jpg
Yikes I found several smoked and crunch connectors in here from previous shorts it is a wonder I did not burn this truck to the ground,
damn how embarrassing. I can't believe I am letting people see this.
so the under dash is demoed, I will get in and clean up some stuff as well as mount a couple anchor points to hang the new harness.
Name:  20180426_121504dash after demo.jpg
Name:  cab after primary demo.jpg
I have a MSD ignition box mounted under the dash that needs to be wired in as well as putting in new defroster and heater ducts.
Old 04-26-2018, 07:43 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Good deal I’m following!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-26-2018, 09:16 PM   #6
Macdaddy1
Brilliant!!!!!!!!
Macdaddy1 is offline   Reply With Quote
Old 04-26-2018, 11:13 PM   #7
63longfleet
yep this is one to follow for me, got the same kit and have been dreading it. Wiring is the lowest of my skill sets.
63longfleet is offline   Reply With Quote
Old 04-27-2018, 03:19 AM   #8
gmcdeadhead
gmcdeadhead's Avatar
i got the same kit last year , it wired right up , good directions, and illustrations, would defiantly buy another autowire kit if i ever had to do it again to another truck
gmcdeadhead is offline   Reply With Quote
Old 04-27-2018, 04:20 AM   #9
BeardedCowboy87
BeardedCowboy87's Avatar
How much money does this kit run?
BeardedCowboy87 is offline   Reply With Quote
Old 04-27-2018, 07:19 AM   #10
Android04
Android04's Avatar
Haven't seen an soldering iron like that in a very long time.
Following as I will be doing this in the summer!
Android04 is offline   Reply With Quote
Old 04-27-2018, 07:50 AM   #11
Hollow65
Hollow65's Avatar
I used the same kit on my 64 and my 65. Was real easy to install.
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 04-27-2018, 07:51 AM   #12
Hollow65
Hollow65's Avatar
https://www.americanautowire.com/sho...66-chevy-truck
Figure $600 and some change after taxes
Old 04-27-2018, 08:09 AM   #13
The Rocknrod
Moderator
The Rocknrod's Avatar
$530 no taxes - https://www.ebay.com/itm/1960-66-Che...sAAOSwhj9aj3Qa
Old 04-27-2018, 08:13 AM   #14
Swatson
which set is this from american autowire?
Swatson is offline   Reply With Quote
Old 04-27-2018, 09:38 AM   #15
Robert Haas
This is the 500560 it supersedes the 500559 with more circuits available.
Couple notes for the hot rodders on here.
If you have aftermarket gauges this kit has a complete separate set of leads already marked to wire into those gauges.
If you have aftermarket heating and AC this kit has outputs for that too.
People with stereo systems. Yep, kit has leads for head units, amplifiers and even multiple Acc, all fused and ready to hook up.
My specific application will need a day time running light output that is switched with the ign. Oh boy that is plug and play and even marked with its very own fuse.
I talked to the nice people at Painless and they do offer a simple "builders" harness but nothing like this kit.
I paid just shy of 6 bills direct from American Autowire and they shipped it with a DVD and it was here in 3 days. I spoke at length with the tech support staff before placing my order and they were very informative and instructed me on every aspect of the kit. I hope I can muddle through this install without bothering them again but they are there waiting if needed.
Old 04-27-2018, 10:08 AM   #16
fredhlynch2
A detailed wiring thread has been much needed. Will follow this very closely.
I think many of us are in this boat and not eager to tackle a full rewire. I have heard that the AA kit is excellent and very doable for the average guy.
fredhlynch2 is offline   Reply With Quote
Old 04-27-2018, 10:12 AM   #17
CRGRS 66
CRGRS 66's Avatar
Sub'd
Thank you Mr. Haas
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 04-27-2018, 07:03 PM   #18
Robert Haas
One step I am taking as it is the perfect opportunity is to clean up the floor and spray some rust inhibitor on any exposed rust or bear metal. So we cleaned up the floor, and sprayed it with some "Flash" aerosol sealer. It is like POR15 but faster. Name:  20180426_103515.jpg
Name:  rust inhibitor during floor prep.jpg
that out of the way it is time for the sound proofing material
You could use dynomat or what ever, I have a commercial product that we are putting down.
Name:  soundproofing install 1.jpg
Old 04-27-2018, 09:15 PM   #19
Robert Haas
So the sound proofing is finished. A lot harder then I thought it would be to be honest but it is important and should keep some heat out of the cab as well. Name:  20180427_174704.jpg
Old 04-27-2018, 10:46 PM   #20
rvrfoot
How many packs did you use?
rvrfoot is offline   Reply With Quote
Old 04-28-2018, 12:44 AM   #21
Robert Haas
5 of the 6
Old 04-28-2018, 09:27 AM   #22
I am in for this
Old 04-29-2018, 03:31 PM   #23
Robert Haas
After demolition and matting is completed we went ahead with the panel installation..
The kit supplies a mounting plate and hardware.
remove 2 upper fender bolts and replace with longer ones, (one at a time)
Name:  bolt before.jpg
changing from this to this
Name:  bolt comparison.jpg
installed
Name:  bolt after.jpg
from the inside you can see how they are now ready to act like studs to hang the panel on.
then hang the panel
Old 04-29-2018, 03:41 PM   #24
Robert Haas
There are a couple new hangers in the kit to hold the harness got those in and started tiding up the loom
If you are doing this on an unmolested original truck it is really a matter of plu and play for 90% of the kit from this point.
We are not so lucky as I have aftermarket instruments, ignition, headlights and stereo.
The kit is designed to bring all of that into use with dedicated wiring and fuses for each system.
Here is the back of my instrument panel.
It has lots of stuff I did to make it work with the old system that I will now cut away and do using the new harness. For example the new harness has instruments lighting as a dedicated circuit that works with the supplied switch with a dimmer, something the original sort of had but didn't work. Also I will now use the new harness to supply signals for the water temp. Volt meter and Tach all that were dedicated loose wires before. The new harness has these leads and they are marked on the wires every 6 inches so future modifications will be so easy.
Old 04-30-2018, 12:30 PM   #25
KIC
1960 GMC Burb
KIC's Avatar
I really appreciate you taking the time to show this. I will be at this phase of my rebuild sometime this year and actually it intimidates the crap out off me. I do appreciate the " if original it is more plug and play as mine is original .. might lower my stress level .
Any additional insight on parts/accessories/tool to buy to help with the process would be appreciated.
1960 GMC Suburban
1/2 ton V-6
2nd generation original owner
60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban
60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs
2003 Tahoe LT
KIC is offline   Reply With Quote
