AC Firewall Harness?
Trying to remove the AC harness at the firewall.
Before I go pulling on the harness at the firewall, is this a plug that goes into the firewall a socket or is it a fixed point that does not come apart? |
Re: AC Firewall Harness?
it goes all the way thru to the box and controls inside.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
That grommets pops out from inside to outside. GM used a moisture sealant barrier so it’ll be tuff at first then it’ll pry out easy. Just use a flatblade to pry under and out on the grommet and it will give way.
| Bookmarks |
