Old 04-27-2018, 06:39 PM   #1
semihippie
Question Rear view mirror mounting
I know this isn't rocket science and admittedly, I'm not the handiest of wrenches.
My original mirror was mounted with just three screws but the mirror itself was loose as all hell. I broke the screw trying to retighten it.
So I got an aftermarket LMC one and tightened it, only to have the three screws that are supposed to hold the mount in place not grab into anything.
So I know of no way to get a nut back there or any trick to use short of using some kind of super glue and hoping it holds.
Right now, I've gotten really good at only using my side mirror.
Any ideas?
semihippie is offline   Reply With Quote
Old 04-27-2018, 06:49 PM   #2
Redneck Rydes
Redneck Rydes's Avatar
Re: Rear view mirror mounting
Stick a piece of mechanics wire in the hole, then put the screws in,cut of the excesse wire and put the cover back over.
Redneck Rydes is offline   Reply With Quote
Old 04-27-2018, 06:52 PM   #3
semihippie
Thanks, I'll do that. I'm guessing you mean bailing wire or is there actually something called mechanics wire?
Old 04-27-2018, 07:01 PM   #4
Redneck Rydes
Bailing wire is the same,just don't go to thick on the wire.
Old 04-27-2018, 07:02 PM   #5
semihippie
Ok, will do. Thanks again
Old 04-28-2018, 12:01 AM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
Or you could do like the MY 1972, with a glue-on bracket on the inside windshield. Not a fan of this installation. It wobbled bad. I've reversed the process on one truck already.
But if worse comes to worst, it's an option. I'd try the wire trick first.
Old 04-28-2018, 12:07 AM   #7
darrellyates
I used a glue-on-the-glass mirror. It's an aftermarket one.... But styled like a much older mirror. Has the chrome day/night knob and everything.
I welded up the holes in the roof during the restoration. I prefer the mirror on the windshield. You could just buy larger self-tapping screws, and open up the holes on the mirror mount if you really want to keep it looking original...
Just my thoughts.
darrellyates is offline   Reply With Quote
Old 04-28-2018, 02:33 AM   #8
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
They say WD-40, duct tape and bailing wire I've added Velcro to the list as well, comes in handy for light applications.
I've found it's difficult to find new tap screws that fit our old Chevys. I believe that's why on occasion there's some dispute #8 Vs #10. The difference may be various thread counts. If a new screw manages to secure, there's a good chance the hole will be too large for the "correct" one.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 04-28-2018, 07:58 PM   #9
franken
My 72 is windshield mount so I went to the self serve scrapyard and ripped on off a random GM windshield and glued it on.
franken is online now   Reply With Quote
Old 04-28-2018, 08:22 PM   #10
truckster
truckster's Avatar
Gently tapping the metal around the screw holes until it's flat will usually push the metal back in far enough that a sheet metal screw will hold.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is online now   Reply With Quote
Old 04-29-2018, 06:29 AM   #11
Andy4639
Old member
Andy4639's Avatar
Talking Re: Rear view mirror mounting
Options always options!
http://67-72chevytrucks.com/vboard/s...d.php?t=432526
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-29-2018, 09:32 AM   #12
my56chevytruck
my56chevytruck's Avatar
I tried the "glue" on the windshield, not once, not twice, but 3 times and the mirror kept falling off. Yes, I cleaned the windshield, and yes I used the correct side to glue on, so I opted for the "original" mounting and screwed the mirror on. Works great, and looks great.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 04-29-2018, 08:16 PM   #13
bill3rail
bill3rail's Avatar
Originally Posted by Andy4639 View Post
Is that picture from a James Taylor song?
Damn this traffic jam
How I hate to be late
It hurts my motor to go so slow
Time I get home my supper'll be cold
Well I left my job about 5 o'clock
It took fifteen minutes go three blocks
Just in time to stand in line
With a freeway looking like a parking lot
- chorus -
Now I almost had a heart attack
Looking in my rear view mirror
I saw myself the next car back
Looking in the rear view mirror
'bout to have a heart attack
I said
- chorus -
Now when I die I don't want no coffin
I thought about it all too often
Just strap me in behind the wheel
And bury me with my automobile
- chorus -
Damn...
Now I used to think that I was cool
Running around on fossil fuel
Until I saw what I was doing
Was driving down the road to ruin
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
