Old 11-10-2003, 10:47 PM   #1
jorgensensc
jorgensensc's Avatar
Gas Gauge question (again)
I tried a search, but couldn't find what I was looking for. My gas gauge worked fine after the blazer tank install (well, 3/4 tank= full, and under empty means empty). Well, I took the gauges out to paint the backs white for brightness reasons, put it all back together installed it, and now I get under empty for 1/2 tank, and almost no movement when full (I went and filled her up to make sure I wasn't crazy and out of gas). I unplugged the sending wire @ the fuse block and te auge went to full. What does it all mean?? Is the gauge supposed to go to full when open?? Is the resistor on the back supposed to go a certain direction? besides left to right? Once again, any help is greatly appreciated!!!Tanks,
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-11-2003, 12:18 AM   #2
jorgensensc
Please guys, a little help. Don't make me beg!!!!!!TTT
Old 11-11-2003, 12:50 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would try turning that resister around, but it sounds to me like your sender is heading south, ot the float don't float as well as it should.
Old 11-11-2003, 12:53 AM   #4
jorgensensc
Thanks for the reply!!!! The sending unit is brand new. Could it be the gauge? Can you really put the resistor on backwards???
Old 11-11-2003, 02:24 AM   #5
SS55
The resistor direction is not the problem! Capacitors and Diodes are polarity sensitive, but not resistors. Is it possible that you tweaked the fuel gauge a little when you had it disassembled for painting?
Be wary of the light at the end of the tunnel....It might be a gorilla holding a flashlight!
71 Blazer, ex-4WD...Bought it that way
55 GMC
55 Belair 2dr HT
67 El Camino
SS55 is offline   Reply With Quote
Old 11-11-2003, 02:33 AM   #6
jorgensensc
I've disassembled this thing a hundred times, this is the first time I've had this problem. Maybe I did tweak it somehow...
Old 11-11-2003, 02:46 AM   #7
SS55
I have seen a bad ground connection cause erratic readings but the symptoms are usually a fluctuating needle rather than what you are seeing, steady but wrong.
I think I have a couple of old dash assemblies out in the garage and if I have a working fuel gauge in the bunch, I can send it to you so you an verify if it is your gauge, wiring or grounding.
Let me know if you want to test one of mine and then loan it to you.
55 GMC
55 Belair 2dr HT
67 El Camino
Old 11-11-2003, 02:49 AM   #8
jorgensensc
That would be great if you could test one. I might be able to drive down (I'm on Camp Pendleton) and borrow it for the day to test it out. Thanks for the offer!!!!!
Old 11-11-2003, 03:01 AM   #9
SS55
I'll test one tomorrow afternoon and let you know if I'v got a working unit.
55 GMC
55 Belair 2dr HT
67 El Camino
Old 11-11-2003, 03:04 AM   #10
jorgensensc
Thanks!!!!
Old 11-11-2003, 11:38 AM   #11
tom hand
CCRider
tom hand's Avatar
I have read on this board of a couple of people getting brand new sending units for the blazer tanks that had bad floats. A pinhole in the float could be your problem.....the float is slowly sinking
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 11-11-2003, 11:59 AM   #12
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
So it worked before you took it out and once it was but back together it didn't work?
What you describe sounds like the gauge is grounded somewhere.
Make sure the leads are isolated and not touching or touching anything else.
Also check the printed circuit board where you plug the harness into it.Check those tabs and make sure they are not bent or crossed up somehow.
Other than moving the needle by hand you can't really "tweek" those things.It's a sealed gauge.
I know I have moved plenty of gas gauge needles by hand with no ill effects.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 11-11-2003, 11:15 PM   #13
SS55
jorgensensc
I sent you a PM
55 GMC
55 Belair 2dr HT
67 El Camino
Old 11-11-2003, 11:23 PM   #14
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
jorgensensc,
did you ever get pics of the filler neck install?
know that its off topic of your problem now, but just wondering.
tommie
tommie is offline   Reply With Quote
Old 11-12-2003, 01:51 AM   #15
jorgensensc
Tommie,
Here are a couple if pics. They are not all I have and I didn't get to get more taken today. I will get to it I promise. I will post the install very soon!!!
Old 11-12-2003, 01:53 AM   #16
jorgensensc
2
Old 11-12-2003, 01:54 AM   #17
jorgensensc
3
Old 11-12-2003, 01:56 AM   #18
jorgensensc
4
As I said before, I need to get pics of the final product, Then I can give you dimensions and a parts list!!!
Old 11-12-2003, 01:56 AM   #19
dinnut
dinnut's Avatar
very nice work. i wanna do that when i goto blazer install. sure the parts from truck shop arent crazy? maybe the kit is cheap for a reason. im not trying to talk bad. im gonna buy a pantload full of stuff from them real soon. im just wondering
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 11-12-2003, 02:43 AM   #20
jorgensensc
Dinnut,
The tank works great, maybe tey are crazy, or don't realize what they got going for them.
Old 11-12-2003, 12:59 PM   #21
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
jorgensensc,
thanks for the pics, wasn't tring to bug you about it, just making sure i didn't miss it when i was at work, and can't get on the net...
Old 11-13-2003, 03:08 AM   #22
jorgensensc
I got the gauge today!!!! Thanks!!! Steve is a really nice guy and I appreciate your help!!!! I have a question though. I installed the gauge this evening and it seemed to work!! I filled up the tank to make sure and it went to 1 notch below full. Is this what it was registering with you? I drove alot and it seemed to go down evenly with the fuel level. Do you think it is my sending unit? It is new. Is there a way to calibrate the sending unit? Also does the length of the wire to the sending unit affect the signal? I know that length can affect voltage, but ohmage? I put a blazer tank in and it is about 5 ft' further than the original wire to the old tank. What do you think?? Thank you again, your a Great Member!!!!!
