![]() Join Date: Jan 2013
Location: 3,018 feet above the SoCal/Mojave Desert region.
Adding A/C to truck.
My '69 doesn't have factory air, but i do need a new dash panel since the stereo was cut out. Will all i need to buy is a dash panel for A/C?? I noticed the A/C dash has 2 holes (1 for driver and passenger) and 2 windshield defroster vents. Is that the only differences?? Thanks.
![]() Join Date: Jul 2001
Re: Adding A/C to truck.
The firewall is different also. It will have to be modified if you are adding a factory AC set up. I am not sure about the aftermarket kits .
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
You will still have to cut holes for your dash vents.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
There is a vent in the center above radio ,do a search on here been covered several times and it is not that hard to do .I and several others cut the dash face out and replaced with a A/C dash face plus installed the cowl vent door and modified the firewall for factory A/C.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 Last edited by kaycee; 04-29-2018 at 10:08 AM. Reason: tumor |
So theres 3 vents? Driver, passenger, above the radio?? And 2 for the wind shield?? I need a new dash panel. The origanl had the original radio stolen, it was cut out.
![]() Join Date: Jul 2017
You could under mount the vents if you dont want to cut your dash.
https://www.restomodair.com/ac-syste...sh-ac-systems/ |
it double posted...not sure why
You'll need a drain hole for the evaporator run off water, so that's another hole in the firewall!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
![]() ![]() Join Date: Jan 2011
Vintage Air in my 68, I used the entire dash panel from an air truck. We cut it apart at the windshield pinch weld. Pics in my build. My cab wasn't a factory air cab.
The latest kit from VA has everything you need. If I ever do another one I'd go the same route, no question.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
