Old 04-28-2018, 04:38 PM   #1
NJKelly
Speedometer not working. 71 Blazer
Hi guys. I've looked at some videos on pulling the speedometer cable out of the transfer case and then spining it to see if the needle moves on hlspeedometer. I'm unsure if by removing there will be oil leaking all over the place. I'm fine with that but I obviously need to replace that oil and don't know where in the transfer case you do that but I'm sure that's on the internet. Just don't want to start it without knowing if oil will leak, thanks. Believe it's an np205.
NJKelly is offline   Reply With Quote
Old 04-28-2018, 07:35 PM   #2
franken
Re: Speedometer not working. 71 Blazer
I doubt it will drip much if at all. A 205 is iron and has a 3" cover on the back center with 3 bolts. Make sure the speedo cable is connected to the speedo--I've see it before.
franken is offline   Reply With Quote
Old 04-28-2018, 09:14 PM   #3
NJKelly
Took it off, no drips to speak of, put it back and now it works, one less thing.
