Old 04-29-2018, 10:13 PM   #1
Submariner616
Active Member
60 C10 Torsion bar cross member rubber mounts
I removed the cross member that the front torsion bar keys attach to and discovered there are rubber bushings on the single bolt on each side that attaches the cross member to the frame. Does anyone know where to find new ones? Thanks!
Submariner616
1965 Chevrolet K20 350 4 speed manual
Submariner616 is offline   Reply With Quote
Old 04-30-2018, 11:49 PM   #2
60burb4me
Re: 60 C10 Torsion bar cross member rubber mounts
Here is what I used I took this part and basically cut them in half worked great hope it helps
60burb4me is offline   Reply With Quote
Old 05-01-2018, 10:47 PM   #3
Submariner616
Active Member
That's a great idea! Thanks! By the way, what did you cut them with?
Submariner616
Old 05-02-2018, 01:45 PM   #4
60burb4me
a razor blade on a mini lathe
