Old 04-29-2018, 11:44 PM   #1
johnwaynejeep
Lower Ball joint myth?
All,
I'm replacing my lower ball joints and need help confirming or expelling a myth.
I recall hearing that new lower ball joints are several thou larger in diameter then original to make a solid fit. Because of this the lower control arms become expanded. I heard that the lower ball joints can only be replaced once. After the 1st ball joint replacement, the entire control arm needs to be replaced during the next lower ball joint service.
Is this true? I can't find any specs on the OE versus replacement ball joint diameters.
Thanks in advance
Robert
P.S. I'm also replacing my upper ball joints, control arm bushings, inner and outer tie rod ends and my idler arm. Then I'm doing an alignment. Full front service.
Robert
1975 C10 - Huckleberry
2007 Jeep JK - John Wayne Jeep
Smittybilt front/rear bumper, 10K winch
Pacific Grove, CA
johnwaynejeep is offline   Reply With Quote
Old 04-30-2018, 07:31 AM   #2
zach_carver
zach_carver's Avatar
Re: Lower Ball joint myth?
Ive rebuilt quite a few front suspensions but Ive never heard that. Some of these trucks may have had lots of ball joints over the years but Ive never noticed any difference all have to be pressed in and out.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 04-30-2018, 09:08 AM   #3
D13
D13's Avatar
Moog problem solvers are oversized to deal with arm pockets that have been enlarged over the years. Most ball joints are not.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 04-30-2018, 04:34 PM   #4
cruizin01
I still had problems with the Moog joints being loose in my control arms. I tried a couple different brands with the same results. I ended up welding them in place. When the time comes Ill replace the arms next time.
'78 C10 Build
cruizin01 is offline   Reply With Quote
Old 04-30-2018, 04:41 PM   #5
TrailerTrash
TrailerTrash's Avatar
I had this exact problem and solved it this exact way
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 04-30-2018, 08:48 PM   #6
sweetk30
sweetk30's Avatar
dodge with the screw in had this problem real bad back in the day .
i have never had much problem with other brands of vehicle .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
