LED King
Engine cleaning and emission hosing
What do you guys use to clean the engine compartment other than degreaser. I was going to use Simple green, but I heard it strips paint. Recommendations?
I replaced my drivers side valve cover. I had a rubber gasket in. Took it out and it was in 3 pieces. I guess that is why it was leaking so bad! Anways, I had to take some emissions hose out to get to it. The hosing after almost 20 years was brittle and cracked everywhere. It was just cord reinforced rubber so I got enough to replace it. My problem is one of the junctions fell apart. It was a 3 3/8 and one 1/4. I can't find the tee anywhere. Can anyone help me out?
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
Stylin
i used simply green on mine this is how it turned out http://67-72chevytrucks.com/vboard/s...threadid=76221 the black spots on my firewall have always been there, im sure it might hurt the paint if u get it on the outside of your truck but i dont think it would hurt the firewall paint, just be sure to get a good angle on the hose if u use simple green and besure to use a good low pressure( either at the car wash or just running water at the house) but u could also just use the engine degreaser at the car wash then run the wash on it then rinse it see how it looks, but use low-mid pressure always unless its just a spot clean or say your cleaning your water pump/powersteering pump then have at it lol. sry this is long winded.... are u talking about the T that goes to the pcv valve then to 2 other places? if so i can ship u a T, ive still got mine.
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ Last edited by crackajacka; 11-11-2003 at 03:23 AM. |
Slots go on anything!
I use Castrol Super Clean, it comes in a purple bottle. It works really well, and won't harm the paint under your hood. I also have a neighbor with a pressure washer. That really helps also.
1974 Jimmy- 5.3/4L80e/NP241 |
Castrol Super Clean is very caustic. It can mess up finishes. I've tried both simple green engine cleaner and castrols, and Simple Green engine cleaner (in the black bottle) is alot better, IMO.
Read the directions first though, because it tells you to rinse the engine first, then apply the cleaner.
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
Hoarding Rusty Objects
This is going to sound wierd, but give it a shot, it will work. Go get a can of gunk engine cleaner. When the engine is COLD spray the whole can on your engine bay. Let it sit overnight. The next morning hose it off. Once the water is dry spray an entire can of tire-shine (the aerosol ones) on the engine bay, yes the whole can. Then let that sit until it dries. You'll be really surprised at the results.
1985 Chevrolet K20 Silverado 1994 GMC Yukon Follow me on Youtube! - http://www.youtube.com/user/FuelInjectionSucks |
LED King
Tire shine = silicone silicone+chrome= streaks!
I ordered the 4 way T from the dealer. I was surprised they still could get it as any emissions hosing parts were discontinued years ago. The parts guy was surprised too! I got a new washer bottle & motor. They now have a new design for the w/s washer motor. When I get it installed I will see how well it works. The one I have now is LOUD. Loud enough to scare people.
Stylin
just asking but how fast do ya'lls windshield wipers move when there on high mine are just down right slow
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
spay some LITHIUM SPRAY GREASE behind the motor where it mounts to the firewall (while the wipers are running). i did that and mine works right now.
2004 Silverado Crewcab (Dark Spiral Gray) |
I use Mean Green. Its cheap and it worked better than Gunk, although I didnt do it the way Moloko said.I found it at Wal-Mart for $2 for 40oz. Its worth a shot.
Jason Perkins Plainview Tx. 1979 Scottsdale SWB |
Right turn Clyde
I use a lot of mean green. It really cleans up tires, gets all the dirt and brake dust off. I soak the tires when they are dry (works a lot better). Scrub them a little then soak them again and then hose them off. They look good but they have a clean but dull look so I use a little bit of tire dressing (low or no gloss) on a cloth and wipe them.
The hardest part about getting the engine degreased is you have to scrap off all the piled on grease and things so the cleaners can get the rest of it. Depends on how gunked up the motor is also but this would be worst case deal. I use mean green because I use it like water. It works pretty good but you don't want to breath it. Its not like carb cleaner or anything but still nasty. Super clean sounds like it a lot more caustic than simple green (mean green) but I haven't used it yet. If you want something totally safe get a brush something like a vegetable washing bush and a bottle of dawn and have a scrubbing party lol
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
