Brake line question....
Would the brake line layout on an 82 K5 Blazer be the same layout as on an 81 C10 pickup? Same bends, routing, etc....
RIZ ![]() 81 C10 short box 82 K5 Blazer |
Re: Brake line question....
2wd to 2wd darn close till under the driver seat area then the rear line will bend a hair different and also be longer on the truck .
4wd to 4wd same info . 2wd to 4wd or other wise will be a bit different as the front lines come out of the frame in a different spot .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
