Old 05-01-2018, 04:12 PM   #1
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Chasing codes on my 97 Tahoe
Hey all, I have had the P0160 and P0161 for a while and finally got around to changing that sensor. Since then I know have P0430. I can clear it and its gone for a couple of days then it returns.
Any ideas?
Thanks for your help!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 05-02-2018, 02:55 AM   #2
87Skier
87Skier's Avatar
Re: Chasing codes on my 97 Tahoe
A code P0430 may mean that one or more of the following has happened:
  • The catalytic converter is no longer functioning properly
  • An oxygen sensor is not reading (functioning) properly
  • There is an exhaust leak
I would start by making sure you don't have any exhaust leaks. Then, if you have a good quality scanner, you can check the O2 sensors to see if they are reading correctly.
Beyond that you will probably need to look at replacing parts.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 05-02-2018, 04:44 AM   #3
Killer Bee
Killer Bee's Avatar
Any ideas?
in bold could very well lead to a damaged cat, not uncommon.. but wise to check the basics mentioned above..
while OBDII is not my primary background, I supervise a few techs that encounter this frequently..
without O2's functioning properly, the ecm relies on base data [usually on the rich side] that may result in extra work for the cat..
once sensor is replaced and system goes into closed loop [feedback], voila, it can now tell you the system is not working efficiently..
this is commonly a now failed cat, but can also be another faulty O2 sensor, still working possibly but reporting bad data [lazy usually]
let us know what engine model, exhaust configuration, number of O2s, cats, etc. and hopefully a well versed OBDII guy can speed this up for you..
also let us know if you have a live data scanner and which one, there are tests that you can run that may lead you to the solution..
there are also LOTS of youtoobs demonstrating your very symptoms, maybe one of them can get you rolling faster as well..
please keep us posted and good luck!
Old 05-02-2018, 06:24 PM   #4
61_FL_Apache
Who Me?
I have a mechanic I call on from time to time and he probably has the scanner needed for more detailed info. I just have a code reader so it doesnt tell you much. The truck runs fine, im getting tired of the CEL. Im surprised the bulb has not burned out yet.
Thanks for the feedback!
Steve
2001 Blazer 4D 2WD
Old 05-04-2018, 04:03 PM   #5
speedygonzales
speedygonzales's Avatar
The previous codes 160 & 161 were after cat O2s. The 430 is cat efficiency.
The rear (aftercat) O2s are only used to check on the health of the cat. They do NOT have anything to do with control of the engine. That is what the front O2s are for.
You need to understand how and when the engine checks on the health of the cats. And thus reading the rear O2s. They are not used constantly.
One thing I can tell you is our vehicles do not like aftermarket sensors. I could never get Bosch to work. And it took days for the code to appear.
Keep that in mind.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
