NEED HELP!! 73 Dually Wheels
I recall reading a thread or two about someone using newer (17 inch) stock dually wheels, does anyone recall what will fit on a stock 73 Dually. I've searched with no luck and the shop wants my truck asap to do some work.
#2 | |
Re: NEED HELP!! 73 Dually Wheels
http://67-72chevytrucks.com/vboard/s...=dually+wheels |
#3 | |
I looked into doing Dodge/Ram 17" 03-11 dually wheels. I like their simulators better vs GM's or aftermarket (they remind me of a chrome, old-school, 'slot' type wheel). The bolt pattern was the same dimensionally but they needed hub centric centering rings so they didn't rely solely on the studs/lug-nuts. Unfortunately, they added ~1/2" to overall footprint (1/4" on the outer side) so I wound up not being able to use them since my set-up is UBER close w/the 16's.
