Old 05-02-2018, 03:57 PM   #1
Jferrante
Jferrante's Avatar
6.0 LS in 66 DBC too short
So I have my motor in and realized that when I hooked the throttle cable up in its original position the throttle body is open a decent amount. I am guessing the motor moved forward with my drop member. What are my options? Adjust the linkage at the pedal or?
Jferrante is offline   Reply With Quote
Old 05-02-2018, 04:37 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 6.0 LS in 66 DBC too short
when you say you hooked the throttle cable in its original position are you talking bout the bracket behind the throttle?..if so then its probably how you have it hooked to your pedal...I would unhook pedal and see if the throttle closes. ..if it closes then the pedal is where it needs adjustment. .
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-02-2018, 05:57 PM   #3
Jferrante
Jferrante's Avatar
Correct - I just looked, i believe you are right and all is good now.
