Old 05-02-2018, 04:09 PM   #1
philB
Question rear coil spring
have a 67 c10, the rear drop spring are CPP 603-5
truck has a lean to one side after installed,
truck was level with worn out stock spring
any way to check the spring may be too light
or any suggestions.
philB is offline   Reply With Quote
Old 06-24-2018, 11:19 AM   #2
Spike 72
Spike 72's Avatar
Re: rear coil spring
Sounds like a quality control issue to me. At least i hope so for your benefit, and nothing is twisted OR deteriorated body/BED mounts. Those springs are soft anyway unless you go with the HD version of the 603.... Return the springs and have a pair of new ones sent back to you. Hope this helps.
Spike 72 is offline   Reply With Quote
