05-02-2018, 04:22 PM | #1 |
Swaybar for porterbuilt arms?????
Ok guys I looked at old threads and I see basically you have to run a pbfab bar or muscle bar. On guy says he thinks it's about 44" eye to eye. I just wonder if this hellwig bar would work. Its 41" eye to eye and 11" deep. Your thoughts????
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
05-03-2018, 10:32 AM | #2 |
Re: Swaybar for porterbuilt arms?????
I purchased a used PB spec'd bar from a board member for my dually because I didn't like the angle of the 'Posi-Links' of the Muscle Bar when installed & they seemed less than stout.
But after only a brief stint under the truck, each side of the installed PB spec'd bar shelled a bushing from binding. I wound up re-installing the Muscle Bar. I'm still researching options for replacing the Posi-Links w/something more robust.
