Old 05-03-2018, 01:20 PM   #1
kaputafj
kaputafj's Avatar
One ton with Manual brakes?
Anyone with a one ton and manual brakes: front disc/rear drum??
67 C10 daily driver (approaching 600,000 miles)
80 P30 family camper
kaputafj is offline   Reply With Quote
Old 05-03-2018, 01:44 PM   #2
Getter-Done
Getter-Done's Avatar
Re: One ton with Manual brakes?
My 1 ton has Manuel brakes with drums front and rear.
Old 05-03-2018, 01:58 PM   #3
binford
My 68 had manual and it was a real b i t c h to stop.
Problem solved by installing the correct master cylinder.
They have 1" for manual and 1-1/8" for power.
The bigger the piston the harder you have to push.
I have 1-5/16 on the 73, but I installed a hydro boost master cylinder.
If you want the best braking power go hydro, provided you have power steering.
My 68 was manual everything
binford is offline   Reply With Quote
Old 05-03-2018, 06:00 PM   #4
kaputafj
kaputafj's Avatar
@binford - thanks. looking to ditch hydro and go manual. Was your system originally manual front discs/rear drums?
Old 05-03-2018, 07:15 PM   #5
binford
No disc brakes. Drum front and rear.
With disc brakes you need move volume of fluid. Just look at the size difference between a drum brake slave cylinder and disc brake caliper, it's like twice the size in diameter.
With front disc and a manual master cylinder you will have a longer brake pedal travel to push the volume of fluid needed. They increased the master cylinder piston size to keep the pedal travel the same, but then needed to add a vacuum booster to help with how hard is was to push the pedal.
The master cylinders are interchangeable and cheap. You will notice about an 1" of extra brake pedal travel with disc and a manual master cylinder.
Normally you have about 3" of travel and now you will have 4"
Old 05-03-2018, 09:28 PM   #6
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
I disagree. If the drum brakes are adjusted correctly and the front wheel bearings are tightened correctly (loose wheel bearings will cause the calipers to move away from the rotors, causing a longer pedal stroke to take up that gap on the first application), the only movement is due to taking up free pedal. The reason for a larger reservoir on a disc brake system is to make up for the loss of pad friction material as they wear, between brake jobs.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 05-04-2018, 08:22 AM   #7
kaputafj
kaputafj's Avatar
So what I'm trying to find is a stock system so I can find a stock master cylinder to use rather than do all the math myself and make educated guesses.
Old 05-05-2018, 04:56 PM   #8
binford
The stock master cylinder are all the same reservoir size.
Im not talking size of the reservoir, I was talking about the the piston size inside of the master cylinder.
Old 05-05-2018, 08:22 PM   #9
Steeveedee
Steeveedee's Avatar
Not all reservoirs have the same size for front and rear brakes, though many do. You are correct about the bore size.
~Steven
Simi Valley, CA
Old 05-05-2018, 11:29 PM   #10
stsalvage
Scrapper 1
stsalvage's Avatar
Never could understand why people back in the 60's -70's did not pay the extra 40.00 for power brakes and steering.It makes like that much easier
stsalvage is offline   Reply With Quote
Old 05-05-2018, 11:38 PM   #11
Steeveedee
Steeveedee's Avatar
Maybe because when the engine quits, it's suddenly way harder to stop and steer. Just a thought.
~Steven
Simi Valley, CA
Old 05-05-2018, 11:50 PM   #12
binford
https://www.speedwaymotors.com/Unive...Bore,4316.html
I looked and it's hard to find a 1" bore
Didn't try NAPA
Says for drum disc
Good luck
