1970 Daily Driver
73-80 metal trim on 81-87
Is it possible to use the older metal trim on the newer square body? I have a 1987 crew cab that I want to do two tone.I love the look of the older style metal trim setting apart the two-tone paint jobs. Does anyone have any pictures of something like this
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
Re: 73-80 metal trim on 81-87
Same here, I've always wanted to see that.
Post Whore
![]() ![]() Join Date: May 2015
I think n2trux is doing something along those lines with the remix truck.... http://67-72chevytrucks.com/vboard/s...d.php?t=762114
working around and the fender lines and the side marker lights may be a issue seeing as to how the front fenders are so different...the rest of the truck is pretty much the same...a front clip swap would make it easier......
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-04-2018 at 05:02 AM. |
A front clip swap is needed. The rest of the body you can retrofit
i wish they made metal trim for the 81+
I don't see any real issue with adapting metal trim and two tone to 81-87. The biggest concession you'd have to make would be to run the trim line and color change clear to the front of the fender. There's no reasonable way to connect the upper and lower colored portions like there is on the 73-80 trucks. It would look more similar to the two tone 1980's Fords(google "1981 two tone ford" for example). The upper trim would need to be longer, so you'd need to use bedside trim on the front fender.
The marker light would be in the way. In Virginia, and likely other states, the side marker light only has to work if installed. It doesn't have to be there. Check your state laws, then close it up, and run the trim in its place. |
Quick Gimp job on the above truck. Hood line lowered and fender lines extended like 81+ trucks. Didn't bother with the grille. Deleted marker light.
Edit to add: might have lowered the hood too much. |
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
Here's a pic that just showed up on a nearby craigslist. I think they're asking eleven grand for the truck. I just thought the two tone treatment on the side was of interest.
