Old 05-04-2018, 09:36 AM   #1
Lakegastonhank
98 k1500 4wd rear drum brake hardware
A wrecker recently pulled my 98 Suburban K1500 (11.15 x 2.75" drum brakes) up onto the flat bed without releasing the parking brake first. It literally tore my drum brakes apart. I am having trouble finding the two parking brake levers and the two parking brake strut bars, as well as the slave cylinder rods. Can anyone please help me find these parts?
Lakegastonhank is offline   Reply With Quote
Old 05-04-2018, 10:33 AM   #2
Big Daddy Bear
Big Daddy Bear's Avatar
Re: 98 k1500 4wd rear drum brake hardware
If they damaged it by doing something negligent, they should have insurance to cover repairing things like that. Have you talked to them about it?
Have you looked at places like RockAuto? https://www.rockauto.com
If RockAuto doesn't have them listed, probably a wrecking yard or maybe (kind of a stretch), a dealership might still have those type parts.
No bolt or nut in the world will remain tight if you turn it to liquid!!!
Big Daddy Bear is offline   Reply With Quote
Old 05-04-2018, 11:06 AM   #3
Mr_Rich
Mr_Rich's Avatar
I still have the backing plates and associated hardware from my K1500 when I converted from drum to disks on the rear axle of my truck. I can post some pics and you can compare the parts if it will help you out. I'm sure I won't be needing them again.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E (sold)
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 05-04-2018, 03:16 PM   #4
JJR
JJR's Avatar
https://www.rockauto.com/info/270/H2323__ra_p.jpg
ROCKAUTO has a couple of different vendors that offer this type of kit but they don't include the flat bars you're needing.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
