Old 05-04-2018, 10:41 AM   #1
67chevemall
67chevemall's Avatar
Question 327 Vin year
What year did they start to put Vin numbers on the engine block?
And are all 327 Vin in the same spot?
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 05-04-2018, 08:17 PM   #2
Re: 327 Vin year
Never on trucks
Old 05-05-2018, 01:23 PM   #3
67chevemall
Re: 327 Vin year
we all know that. most are all car blocks.
I am sure there was a few years with blank blocks
Old 05-06-2018, 07:15 AM   #4
Re: 327 Vin year
You are asking your question on a truck forum
Old 05-06-2018, 10:09 AM   #5
Coley
Coley's Avatar
Re: 327 Vin year
I think the 327 was available on the trucks from '65 to '68....to my recollection.
You won't find any of those with VIN numbers on the block tho', as already stated.
As for the cars...who knows, late 50's? When did the 327 first appear...1960 to '62?
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 05-06-2018, 11:03 AM   #6
Bigdav160
Bigdav160's Avatar
Re: 327 Vin year
I've read, for Corvette, it was January of 1960
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-06-2018, 01:51 PM   #7
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
Re: 327 Vin year
A quick search on the inter webs say "the last 6 digits of the VIN were stamped into the blocks on Corvettes in 1961 or 1962. In 1964 GM stamped the last 6 #'s of the VIN in the higher HP motors i.e. 327-300HP and 409's. In 1968 the feds required all auto manufacturers to stamp identification #'s into blocks." Not sure why trucks of our area were exempt. Maybe due to the low HP? I know in the 70's when I was combing the wrecking yards for motors I never even considered a truck motor. Always the 327 with camel humps or LT1 motors. I guess in my ignorance at the time I could have missed the Factory 1967 L79 Corvette motors installed in the trucks lol.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 05-06-2018, 04:27 PM   #8
Re: 327 Vin year
You missed the '68 C/20 large Journal high nickle steel crank 327. One of the best small blocks for building. The same block/suffix code would be found on the '68 SS350 Camaro.
You also missed all the steel crank 4-bolt truck 350s through '75. Both are great motors to build. The latter is what I prefer for a 383 build
Old 05-06-2018, 08:32 PM   #9
Canuckvetter
Re: 327 Vin year
Oh to be young again knowing what I forgot now.
Old 05-06-2018, 08:52 PM   #10
Re: 327 Vin year
I know what you're saying. I missed a lot. I also knew what would always be worth keeping, but had to let it go. Still doing it.
Old 05-11-2018, 10:59 AM   #11
67chevemall
Re: 327 Vin year
OK I cleaned the modor and got some numbers.
K05010 GA
Other then it was made here inow st catharines
I don't know what the rest means
Old 05-11-2018, 11:04 AM   #12
geezer#99
geezer#99's Avatar
Re: 327 Vin year
Suffix code GA says it’s a 283.
http://www.nastyz28.com/gm-chevy-cod...s-suffix-5.php
What’s the casting number?
Old 05-11-2018, 12:03 PM   #13
Coley
Coley's Avatar
Smile Re: 327 Vin year
Geezer's correct.....not a 327 engine given the GA suffix.
Its a '65, 283 (195hp)....looks from a full size car.
Is that what you were expecting? or did someone say it was a 327?
Coley
2000 Dodge Ram 1500
Old 05-11-2018, 12:24 PM   #14
bruceman1968
bruceman1968's Avatar
Re: 327 Vin year
67chevmall, you got a extra digit or a incorrect digit in there.
K05010 GA
K= McKinnon Industries St. Catherines, Ontario
05= May
01= 1st
0= This is extra or incorrect(possible stamping error)
GA= 1965, 66, 67 283ci or 1968 307ci or 1969 327ci. All Impala motors.
If your extra 0 is a C then your suffix code is CGA
CGA= 1971 350ci or 1975/6 262ci
Can you double check your stamped application code(K05010GA) and get your casting number and date code off the block. Here is a pic showing locations.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 05-11-2018, 12:51 PM   #15
67chevemall
Re: 327 Vin year
The ad said 327 and the po said 327.
Awesome always wanted a 283.
Thanks for the info you guys are great.
I will look around more tonighthan
What is the trick to see the numbers at the back of the block?
Old 05-11-2018, 12:57 PM   #16
67chevemall
Re: 327 Vin year
You guys know your stuff.
How about the 3 speed?
M3 3868632 is on the case
7 bolts
Old 05-11-2018, 01:00 PM   #17
67chevemall
Re: 327 Vin year
I will double check the number.
There is a space between the 0 and GA sof can't be 0GA
Old 05-11-2018, 01:02 PM   #18
67chevemall
Re: 327 Vin year
--^-- and the mark on the front of the heads
Old 05-11-2018, 04:31 PM   #19
MARKDTN
Re: 327 Vin year
Is it large journal or small journal?
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-14-2018, 08:14 AM   #20
67chevemall
Re: 327 Vin year
K05010 GA
05= May
01= 1st
Attachment 1783689
Yep the numbers are right. Extra number is a 0
And I can't see the numbers at the back. Maybe a mirror would help....
Old 05-14-2018, 08:29 AM   #21
geezer#99
geezer#99's Avatar
Re: 327 Vin year
Yup!
A mirror and a flashlight.
Point the light into the mirror and everything back there lights up.
Old 05-14-2018, 10:09 AM   #22
Re: 327 Vin year
I need to know!!
Old 05-14-2018, 11:20 AM   #23
67chevemall
Re: 327 Vin year
69 327 Impala motor
Old 05-14-2018, 12:08 PM   #24
geezer#99
geezer#99's Avatar
Re: 327 Vin year
And what was the casting number?
Old 06-12-2018, 11:11 AM   #25
67chevemall
Re: 327 Vin year
front numbers.
I can't see the ones on the back. I think my sb might be in the 6 cly spot.?/?
