Old 05-04-2018, 07:23 PM   #1
Cristiann8
Fuel tank relocation fuel line
I’m relocating the fuel tank to the bed and I was wondering where can I get a steel fuel line that’ll run from the tank in the bed to the front to the fuel pump? I do not want to run rubber fuel line all the way to the back to front.
Cristiann8 is offline   Reply With Quote
Old 05-04-2018, 08:31 PM   #2
SeanB242
SeanB242's Avatar
Re: Fuel tank relocation fuel line
I used the stock fuel line in the frame rail. Just ran a piece of rubber on each end. Not ideal but it’s all I had. Will probably redo it. You can get fittings and some braided line from summit. What type of tank are you using? If you used a Blazer tank then you could get a factory Blazer line that would make up most of the run from front to back.
SeanB242 is offline   Reply With Quote
Old 05-04-2018, 08:32 PM   #3
rjs53
Might look at a blazer fuel line, seems the tank was in the rear. Hopefully someone knows for sure
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 05-04-2018, 08:41 PM   #4
Trackman101
Trackman101's Avatar
Buy 3/8s SS tubing and compression fittings.
Bend to suit.
Trackman101 is offline   Reply With Quote
Old 05-04-2018, 10:11 PM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
Except that the K/5 is 104'' [wheel-to-wheel centers], a shortbed is 115'' and a longbed is 125''.
Old 05-05-2018, 01:04 AM   #6
SeanB242
SeanB242's Avatar
Which is why I said it would cover most of the length and said to get braided line and fittings😃
Old 05-05-2018, 01:51 AM   #7
'68OrangeSunshine
Or you could get lines for a Suburban, and cut off what you don't need.
Old 05-05-2018, 03:04 AM   #8
SeanB242
SeanB242's Avatar
Or that
