Old 05-04-2018, 07:26 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Gaskets - questions
71 C-10 SWB
Any recommendations for intake, timing chain, valve cover and oil pan gaskets? For what it's worth I'm working on a 402, and the truck is being restored to mostly original.
I hear the best oil pan gasket is a one piece Fel-pro. I've read someone say you need to silicone the corners, but seems most don't use any sealant. What do you think?
All suggestions appreciated, thank you.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 05-04-2018, 08:54 PM   #2
SeanB242
SeanB242's Avatar
Re: Gaskets - questions
Just used a 1 piece oil pan for the first time. I didn’t use any silicone but the truck isn’t drivable yet so I don’t know if it’s going to leak. I can say it was a joy to install compared to the original type. It was felpro and has the spacers in the holes so you can’t “crush” the gasket. Intake gaskets were felpro but I used sealer on the ends instead of the rubber. I have a 2 piece timing chain cover so I just made a gasket out of cork gasket material.
SeanB242 is offline   Reply With Quote
Old 05-04-2018, 09:00 PM   #3
6T7 C10
x3 on the Fel-Pro molded silicone gaskets. I recently put one on a SBC with no leaks so far. Easy to install and probably reusable within reason. They seem to be a high quality gasket. Much better than the old school stuff.
6T7 C10 is offline   Reply With Quote
Old 05-04-2018, 11:22 PM   #4
71CHEVYSHORTBED402
All good to know thanks. At this point I'll approach the oil pan without sealant. I know it's required for the intake, though I didn't know rubber strips were an option.
On a side, these projects are resource intensive man. My engine block was pretty clean, but I'll spend a good part of three days for spotless, clean threads and that.......and it's on a stand. You figure it's worth turning the block upside down to install the oil pan? Spinning the block isn't a problem. Might see some oil spills - other unknown issues.
Old 05-05-2018, 09:58 AM   #5
davepl
davepl's Avatar
We used all Felpro and when done, hooked it up to a SnapOn smoke machine. Under pressure, smoke came out of about 4 different places on the valve covers and timing cover. All it took was a little hammer and dolly work, but they sure weren't beat up or anything.
Moral of the story is that if your mating surfaces aren't flat and true, it's going to leak no matter how good your gaskets are, so start with the basics!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-07-2018, 02:00 AM   #6
71CHEVYSHORTBED402
That's meaningful, thank you. I took my valve covers to a body/paint friend to work out what I couldn't. I noticed the inside edges were somewhat warped from bolting it down. Thought it might work, probably not enough and now know better. I'll ask him to flatten the bottoms as well. I need a dolly set.
Cleaned up the engine today. Next up oil pan @ timing chain gaskets. I figure to paint with the pan, chain cover and intake on. Knowing me that's going to take a while. Painting by hand, POR15 Chevy Orange. I hear it's a nice affect.
Old 05-07-2018, 11:00 AM   #7
71CHEVYSHORTBED402
Called Felpro on their one-piece pan gasket. He says "yes seal the four corners as per directions". Haven't bought the gaskets yet. I know a lot of people don't use sealant with the one-piece. I wouldn't fret about it.
For what it's worth, he says 12 ft. pounds torque on the pan.
Old 05-07-2018, 11:06 AM   #8
BCOWANWHEELS
felpro, n use sealent on pan corners 4 sure. permatex ultra black
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 05-07-2018, 01:43 PM   #9
71CHEVYSHORTBED402
Nice how to videos:
Timing chain cover seal: https://www.youtube.com/watch?v=sR8z21I68WA
Timing chain cover: https://www.youtube.com/watch?v=daa5bGZXYuk
Cork oil pan gaskets: https://www.youtube.com/watch?v=VdUo-Ts4Acw
https://www.youtube.com/watch?v=tHyIPiAHR6Q
https://www.youtube.com/watch?v=LuNuv6y2css
https://www.youtube.com/watch?v=1MzHlqQFHcs
