11-11-2003, 03:13 AM | #1 |
Stylin
blower motor still wont work
my blower motor still doesnt work. what do i need to check to make sure im getting power to the motor? the vaccum crap still works if ive got it hooked up lol. but ive delayed long enough i need my heater blowing hot air so when it actually does get cold ill have one, instead of driving fast and hot air blowing threw anyways lol.
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
11-11-2003, 03:33 AM | #2 |
First thing to do is to use your multimeter to make sure you're getting power out of the switch. If that works, the next step is to make sure you're getting power to and through the resistor pack. Lastly would be checking voltage at the blower motor plug itself.
Brian |
11-11-2003, 11:09 AM | #3 |
Insert Witty Text Here
When my blower motor went out it was because a wire in the connector nearest the blower motor had burned up. It is hard to describe, but I have heard from a couple of other people that they had the same problem, and it is quick and easy to check.
Slonaker |
11-11-2003, 12:02 PM | #4 |
have you checked the motor itself? if not, take a wire from the battery to the blower motor, dont hold it on there long cause it will melt the wire to the battery, but if the motor is good it will make it run. Mine hasnt been working lately, the connection had come off. i had to push it on there real good for it to make connection. if you are testing things, i would start at the blower motor and work your way to the dash switch, as the switch is the hardest to get too.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
