Old 05-06-2018, 12:35 AM   #1
71gmcC15
71gmcC15's Avatar
Rim and tire fit ment
I looked and could not find quite what i needed for an answer. I want to run 15x8s all around with 4in backspaceing with 265/75s all around. This is on stock ride hight c15. Can i do this with no problum? I have factory disc up fount if that makes a difference
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 05-06-2018, 01:54 AM   #2
MQUnlimited
MQUnlimited's Avatar
Re: Rim and tire fit ment
Take a straight edge and lay it diagonally across the inboard flange of the wheel. Take a tape measure and measure the distance from where the straight edge contacts the inboard flange to the hub mounting pad of the wheel. This measurement is backspace.
To determine caliper clearance.
A. Caliper Overhang Distance
Used to determine if wheel dish is adequate (in some cases a spacer is required for clearance)
B. Diameter of Hub Center
Required if wheels are hub centric
C. Wheel Stud Diameter
Required along with bolt circle
D. Height of Hub Center
E. Length of Lug and Thread Type (Fine or Coarse)
Required to determine if longer studs are necessary
F. Distance from CL of Hub to Caliper
Used with A to determine if a spacer is required for proper fitment
G. Width of Caliper
Used with F to determine if wheel ID is adequate to clear rotor/caliper package
H. Diameter of Hub Mounting Face
Used to determine if hub is adequate to support wheel/spacer
MQUnlimited is offline   Reply With Quote
Old 05-06-2018, 08:44 AM   #3
painterljp
Ours has 265/75/15's. They work just fine 15x8 Rally. Ours is 68 has drum all around though. Have an 88 blazer 6 hole rally. Same wheel with disc on front. They are factory from that year but work fine also.
painterljp is offline   Reply With Quote
Old 05-06-2018, 10:47 AM   #4
71gmcC15
71gmcC15's Avatar
G. Width of Caliper
thanks this will help
Old 05-06-2018, 10:55 AM   #5
71gmcC15
71gmcC15's Avatar
That lookes realy good. Thanks. I alway loved the look of the rally wheels. Im going with slot mags.
