05-07-2018, 10:14 AM | #1 |
Converting a 1968 k10 to power steering.
Can someone direct me to an existing thread that would help me work out the details of converting a 1968 k10 to power steering? I have a 1985 Corp 10bolt front axle, power steering box, pump and new control arm, drive links, and pitman arm. I just need to attach the box to the frame with the correct geometry. Any help is appreciated.
Posted via Mobile Device |
05-14-2018, 07:26 AM | #2 |
Re: Converting a 1968 k10 to power steering.
I don't know of a thread to share on this, and I have not done this swap. But I have always felts it would be exactly what you are doing...change everything involved. Probably all you need is the location of the steering box on a '70-'72 from a given point on the frame, since frames are no different other than steering box mounting. Pick a point and I'll see what I can do on my '72. What would be better is if someone has an open chassis.
05-16-2018, 12:46 PM | #3 |
ck with captain fab he makes what you need. plate to mount the steering box.
1961 chevy K10 my build is------------61K10 build |
05-17-2018, 12:50 AM | #4 |
68 frame should be dimpled where the box bolts on. So everything is a bolt on, 'cept the pressure line unless you use the 85 pump with the early brackets depending on which engine you have and the pulley system
05-17-2018, 01:03 PM | #5 |
thought it might be dimpled, just a year off lol.
05-27-2018, 12:22 PM | #6 |
68 frame is not dimpled for PS. I did this swap on my hulk jr build around post 63 link is in my signature. I used captain fabs bracket and a steering shaft I met I found at CPP. I used stock 72 PS hoses from the parts store
I hope this helps
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
05-27-2018, 10:47 PM | #7 |
If it is a real 68 it should be dimpled
05-28-2018, 02:21 PM | #8 |
Not sure about that, as all 67-68 that have Manuel steering boxes some just had hydraulic power assist and not a actual power steering gear box.
Maybe a half year thing? Early 68 versus a late 68? 69 up had the dimpled frames. Interesting non the less.
05-28-2018, 04:59 PM | #9 |
See post number 7
I have 2 68s both were dimpled. Every 68 I've seen has been, beit manual or power steering. Never seen an assisted 68 only 67 and older |
05-29-2018, 12:02 AM | #10 |
Well check out my post 6. It has directions to a true 1968 k10 LWB that is not dimpled. Because you haven’t seen one! After you check it out you can say you have . Good luck Clivis.
