1972 c-10 project
Been looking for a couple months now for a solid 67-62 c10 and finally came across one in my area. It’s a 1972 c10 swb project and the guy is selling it as a roller. He has everything for the truck minus motor and trans. His asking price is $3500, is that a good deal for a solid 72 swb c10?
Posted via Mobile Device |
![]() Join Date: Mar 2011
Re: 1972 c-10 project
if you have no rust thru grab it, you can part it for more...of coarse you can always part for more ....steel bed floor ? no real transport cost cuz its local..... see what other parts he has to throw in ...looks like he shaved the firewall? one pic shows glass then doors off & no glass make sure you get it all ....just my 2 cents
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
Yep, check for rust in all the locations and make sure it's a genuine SWB. That price seems good for the current market if it's a real short bed and a good solid cab/frame.
It has a steal bed floor. I went and looked at it over the weekend. It comes with front bumper, grill, seat, glove box, gauges, headlights, marker side lights, both doors with glass in both of them. The doors where hung on the truck when I went and looked at it. I checked the frame and the body where the normal rust areas would be and it seemed to be a really solid truck. It doesn’t come with the windshield though. Is $3500 a good price for this truck?
Posted via Mobile Device Last edited by JeffCuddy; 05-07-2018 at 11:48 PM. |
The value is what your willing to pay for it, in my opinion. He's asking $3500 for a roller that needs everything, and everything that is there needs to be replaced or rebuilt. It looks straight and seems to be a good starting point, but you figure he's asking about 10% of what your going to put in it, just to make it a nice driver. I would definitely start lower. Not an insult lower You can always go up but never down. If he's had it for a while that's a good thing, might be willing to drop right away.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
agreed.... make a REASONABLE offer dont insult him if you want the truck ....let us know how you make out
![]() Join Date: Oct 2011
$3500 is a good price for that truck but (as always) if you can get it for a lower price then that always is a bonus.
As mentioned, the trick in getting it for less....is not to make a disrespectful offer. (noting that there is a difference between a low offer and a disrespectful offer) Take 15-20 minutes and make a quick inventory of what might be missing...ie: seat? either bumper? both bumpers? tailgate? bumper brackets? instrument cluster? steering wheel? inner door panels, carpet?.....this will have a bearing on pricing if it is a major item that is difficult to source and an expensive item to buy to make it a driver, etc. I would offer $2500 and have the money right there in $100 bills and tell me him you can have it all out of his way within the day. Good luck, keep us posted. All good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
#8 | |
That is a great buy in my area .
There is also another 72 swb c10 in my area for $2200. Guy says it’s all solid except for rockers and cab corners. He says he’s got everything for the truck except motor and trans. Does that sound like a better deal?
Sorry to chime in... No. Not in my opinion. Well, if you can do all the sheet metal replacement yourself, maybe. Likely, corners and rockers can turn into cab supports, lower A pillars, kick panels, maybe a floor.... You get the idea. If the $3500 one is REALLY solid, that's a good deal. The cab is worth $2000 to $2500 if it's solid, the frame another $1000, the assorted sheetmetal (front end) is about $750 or so, and the bed will likely bring about $1000. So, $3500 isn't out of line for the truck. Don't insult him, just nibble and get it for what you can. I believe the better truck is less expensive than fixing the cheaper one. Just my opinion... I bought what I thought was a solid cab, then spent about $3000 fixing the darn thing after I sandblasted it... So to me, $3500 for an almost complete, solid truck, doesn't sound too bad....
Look inside the cab down in the corners, use a flashlight if you have to. Like darrellyates said, that extra money will save you a lot of time. I just bought a running 69 long bed, $2,500. The cabs the same lwb or swb. I should have run my hand down inside the cab corners, they did a nice job covering everything up. I ended up replacing everything except the center hump. The sheet metals cheap but definitely more work than I really wanted to put in it. I would climb under both before pullin out the cash.
#13 |
Scrapper 1
1 rule power coat the core support the battery like to eat the passenger side plus your radiator will rust out the rest over time
