![]() Join Date: Jun 2014
WTB - Climate Control Lamp Socket and Pigtail
Need one of the above with enough of the wire left to the socket to splice it in. I think A/C and no A/C controls are the same. These light up the controls at night.
Thanks! Randy |
![]() Join Date: Jul 2001
Re: WTB - Climate Control Lamp Socket and Pigtail
Randy, I'm parting a '70 3/4 CustomCamper/20. Has some of the underdash wiring still. Was an A/C truck, believe that wire is a small 14 ga. gray wire with a small round headed glass bulb. Pretty sure it is still hanging under the dash. Will look and get back with you.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Hey Ironhorse. That sounds correct. LMK details.
Thanks, Randy |
Randy, pic of the heater/AC control panel bulb and socket. Gray wire is about 7-8 '' long. Checked and the bulb still works, not sure what the bulb # is. Glass seems a bit loose to the bulb base but since it still works did not try to remove from the socket. If this works for you, PM me your address and I will get it headed to you in the mail.
Got it Gary!
Thanks! Randy |
Glad you can use it Randy !
