05-10-2018, 04:20 PM | #1 |
Spindle nut question
Does anyone know if my stock brake drum spindle nuts will fit McGaughy's disc brake spindles? I got a great deal on the spindles but they did not come with the nuts. I don't have a nut that will thread onto it or a thread gauge. I am not to the point of installing the disc brake system yet, still gathering parts but if I can use the nuts from the drum brake spindles I will do that.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
05-10-2018, 10:13 PM | #2 |
Re: Spindle nut question
I’d imagine if they didn’t supply it then it’s assumed you’ll use the old one. I would imagine they would use the stock style nut and thread type. If it is wrong you’ll know it.
05-11-2018, 09:28 AM | #3 |
I didn't buy the spindles from McGaughy's, I got them second-hand. The thread looks like 3/4-20 I guess I will cross that bridge when I get to it.
05-11-2018, 10:00 AM | #4 |
Here are the ones I ordered when I put my new spindles on.
https://www.rockauto.com/en/moreinfo...=1261288&jsn=1 I did not try the old ones... |
05-11-2018, 10:15 AM | #5 |
Jason, thanks for the link.
07-26-2018, 02:49 PM | #6 |
I ended up using Dorman P/N 05193 nut/washer/cotter pin kits and they worked perfectly. Rock Auto, $4.03 each
07-26-2018, 03:09 PM | #7 |
67-72 parts collector,…
I’ve used drum brake spindle nuts with ECE drop spindle.
Exact same size and thread pitch.
