Old 05-10-2018, 04:27 PM   #1
Fred n' Ethel
Fred n' Ethel's Avatar
Tarpaper substitute ?
!954-3100, stock fuel tank behind the seat.
Just putting it back in.
The tarpaper pads are in poor shape / missing.
What would be a good alternative ?
I have 1/8" cork gasket sheet.
Or, I could fold up some 15lb. roofing felt and nearly duplicate the original.
Or an asphalt shingle (grit removed)?
What would you use ?
Fred n' Ethel is offline   Reply With Quote
Old 05-10-2018, 04:34 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Tarpaper substitute ?
my under cab tank had tarpaper on it...I was gonna go back with new tp....it worked for 60yrs...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-10-2018, 04:37 PM   #3
Fred n' Ethel
Thanks Greg.
This stock stuff is much thicker than any felt I have available.
I'll fold up some of the roofing felt to an adequate thickness.
Cheers.
Old 05-10-2018, 04:41 PM   #4
mongocanfly
Post Whore
there is a real heavy industrial roofing felt...doubt that big box stores have it....folded should be fine...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-11-2018, 01:10 PM   #5
_Ogre
_Ogre's Avatar
i believe oem was 100 lb roofing felt, pretty tough stuff
cork, rubber or plastic would probably work as well
shop air compressor timer
Old 05-11-2018, 06:15 PM   #6
Fred n' Ethel
That sounds about right Ogre. I have some 30lb which is a bit light, so instead of tripling that up, I just put 1/8" cork gasket sheet under it. I had quite a surplus from an auction.
On another note ... dead center of the floor, under the seat is a strange shaped hole through the floor. Looks similar to the pic. What was it for ? and what was used to plug it ? Might explain all the mouse turds under there.
That's a rough sketch, I'll get an actual pic if necessary,
Old 05-11-2018, 06:19 PM   #7
_Ogre
_Ogre's Avatar
aliens! run!
Old 05-11-2018, 06:21 PM   #8
Fred n' Ethel
So, you're sayin' they might NOT be mouse turds ?
Old 05-11-2018, 06:27 PM   #9
Fred n' Ethel
better pic. Poor, but better.
Old 05-11-2018, 07:39 PM   #10
mongocanfly
Post Whore
I'm guessing under seat drain hole....mine has it to...it shows it in the assembly manual but doesn't say what it is...mine has it to...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-11-2018, 09:58 PM   #11
greg_h
I wondered if it could have been a way to "tie up" the torque tube driveshaft prior to engine installation. Maybe some sort of twist and release holder...seems like it is in about the right location best I recall.
greg_h is offline   Reply With Quote
Old 05-11-2018, 10:09 PM   #12
mongocanfly
Post Whore
doubtful....I think the entire chassis was built first...then the body installed...just my guess though. ..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-17-2018, 09:36 PM   #13
Matt_50
The padding he asked about... what it used on 1950 tanks too or was the tank just strapped in?
1950 Build
Matt_50 is offline   Reply With Quote
Old 05-17-2018, 10:20 PM   #14
Fred n' Ethel
I would suspect it was under all of them.
To keep metal to metal contact from happening.
Good idea, imo.
Old 05-17-2018, 10:23 PM   #15
Matt_50
I thought so, I must have missed it when I looked in the LMC catalog. Anywhere there's contact there should be something right? So where it sits and where straps go...
1950 Build
Old 05-17-2018, 10:27 PM   #16
Fred n' Ethel
There was none under the straps on mine, just the 4 spots where it sits in the cradle. That's where the weight is and likely where the cushioning is mostly required should there be any movement.
