Old 05-11-2018, 08:32 PM   #1
BBCamaro
BBCamaro's Avatar
Ac wire question
I have a 71 Chevy and the air compressor won’t engage however I did notice that there is a plug under the dash(2green wires and 1 yellow) it’s a 2 post plug and I can’t find where it plugs in .. any help will be appreciated.. thanks
BBCamaro is offline   Reply With Quote
Old 05-12-2018, 01:10 AM   #2
kwmech
Re: Ac wire question
If I'm not mistaken it should plug into the switch near the center vent? (if that makes sense)
Old 05-12-2018, 05:40 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Sounds like the 2-prong plug that goes to the A/C compressor switch. Kinda hard to find but it's located behind the heater box under the dash, slightly to the right of the cig. lighter. This is what you're looking for:
The switch mounts with the connector prongs down, and the button activator on top. The button is operated by the A/C and Heater outlet slider at the center of the HVAC control.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 05-14-2018, 10:16 AM   #4
BBCamaro
BBCamaro's Avatar
Yes that’s it....mine is missing but at least I know what I need now.. thank you
Old 05-14-2018, 08:49 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Glad I could help. Last year we did a lot of A/C work on my K20 and had several issues. Installed virtually all new parts but compressor would not come on because that switch was faulty. Had a bear of a time finding it and replacing it.
Good luck with yours.
- Mike -
RIP El Jay
Old 05-14-2018, 09:57 PM   #6
BBCamaro
BBCamaro's Avatar
I do have another question.. the pass floor vent opens with vacuum but doesn’t close .. is there supposed to be a spring on the door to close it??? Thanks Jim
Old 05-15-2018, 12:58 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yes, there's a spring from the vacuum actuator to a tab on the vent door.
- Mike -
RIP El Jay
Old 05-15-2018, 01:23 PM   #8
BBCamaro
BBCamaro's Avatar
Thanks again.. Jim
