Old 05-12-2018, 07:33 PM   #1
67pete300
Which driveshaft?
I am replacing a 230/3 speed with a 4.8/4L60 from a 2006 2wd regular cab truck.
I currently have both driveshafts (still removing stuff from the donor truck.)
Should I keep the nice, large diameter, lightweight driveshaft from the donor? Can that be shortened?
Or should I just use my existing stock driveshaft?
67pete300 is offline   Reply With Quote
Old 05-12-2018, 10:07 PM   #2
66 C10 383
Re: Which driveshaft?
Is your current driveshaft a single shaft for a shortbed or a 2 pc with a carrier bearing for a longbed?
I'd measure the driveshaft opening in the trailing arm crossmember and see how it compares to the diameter of the shaft from the donor truck.
I'm not sure if the donor truck shaft can be shortened. It's probably aluminum.
Depending on which mounts you use, some guys put the engine at the same distance as the old engine and just reuse their stock driveshaft.
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 05-12-2018, 10:10 PM   #3
67pete300
The current driveshaft is a single shaft (shortbed). The new one is aluminum and very light.
Will have to keep reading to see which mounts will allow the same shaft.
Old 05-12-2018, 11:21 PM   #4
66 C10 383
You could look into the Dirty Dingo sliders or any adarter plate but you'll have to figure out the amount of set back to put the trans back in the same location.
Doug
Old 05-13-2018, 06:41 AM   #5
homemade87
The alum driveshafts can be shortened . I have shortened 3 of them . I have a small local machine shop that does it for me . Just need to leave it assembled so they can chuck it up in the lathe . Also it is marked so it is clocked the same . No problems with the 3 I have .
homemade87 is offline   Reply With Quote
Old 05-15-2018, 05:49 PM   #6
67pete300
So I'll assume I can use my stock driveshaft as is or have it shortened.
I'm about to get rid of the donor truck and will send the aluminum driveshaft with it.
Do I need to keep the slip yoke from the donor truck? Or will the stock driveshaft yoke fit on the 4L60? Or something different altogether?
Old 05-16-2018, 09:09 AM   #7
truckdude239
truckdude239's Avatar
Saginaw 3 speed yoke will fit the 4l60e i had my oringal shaft shorted and rebalacned
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-22-2018, 07:23 PM   #8
332rick
332rick's Avatar
Keep the yoke that goes to the 4l60 transmission and then get a conbo U-Jiont to match the older shaft.
the 2 pc shaft will need to be shorten and tuned
332rick is offline   Reply With Quote
