05-12-2018, 10:26 PM | #1 |
steering linkage help
I am rebuilding the steering linkage on my truck and the new pitman arm I have seems too big for the drag link. Does it have to be pressed into the drag link? or is it supposed to be an easy fit? Do I have to drill out the center link a bit for the new pitman arm to fit?
1986 Chevy Fleetside Wrangler (Canadian Only) |
05-14-2018, 10:09 AM | #2 |
Re: steering linkage help
It should go in (tapered fit, it's pressed in when nuts tighten) make sure you line up the tapers . If you revers the tapers it will be very hard to get them in will mess up the part!
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
05-26-2018, 09:53 AM | #3 |
thanks I found the problem. The kit I bought from Performance Online they sent me the wrong idler arm. It had two large tapers instead of the one small and one large for the drag link. Bought the proper one locally.
