Old 05-13-2018, 12:10 PM   #1
tim71
tim71's Avatar
Steering Issue
I'm curious if that it is normal for my K1500 to rock (lift) the front of the truck when I turn the steering wheel while the truck is not moving. Turn wheel right, left side lifts, right side dips. Turn wheel left, left side dips, right side lifts. Would this be inherent to a solid axle/leaf spring front suspension?
1972 Blazer Highlander
1971 GMC K1500 SWB (sold)
2004 Corvette Z06 CE
tim71 is offline   Reply With Quote
Old 05-16-2018, 04:16 PM   #2
BCOWANWHEELS
Re: Steering Issue
check your ball joints jack up front end look for play
BCOWANWHEELS is offline   Reply With Quote
Old 05-16-2018, 04:33 PM   #3
dell72
Re: Steering Issue
your truck will move around due to the tires moving through the arc of travel and caster and camber angles changing. This will be more noticeable when the truck is parked versus moving down the road.
dell72 is offline   Reply With Quote
