stall convertor???????????
can someone explain stall converters to me please what would be the difference between a 3500 and a 2500.ive heard someone say they dont like 3500,but why ?why would someone like one and not another.i know nothing about them at all.thanks in advance
springfield illinois 2003 custom (harley)built from scratch 68 swb |
Keepin an eye out
I too would like to know the principles on how they work and how to tell if you already have one.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
CCRider
http://www.turboaction.com/conv_techtalk.html
http://www.carcraft.com/techarticles/80098/ http://www.tciauto.com/tech_info/tor..._explained.htm
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
![]() Join Date: Feb 2000
Well heres my explaination of a stall converter.
First most converters are for 1600-1800 RPM. This means that you can hold the brakes and get on the gas up to near that RPM without the tires starting to spin. For a 2500 RPM stall, You can bring the RPMs up to the stall of 2500 RPM, a 3500 Stall = 3500 RPM. The idea is that this allows you to get your engine up into it's power band RPM range before the tires start to get power. A engine with a large cam needs a higher stall to get it into the power range, thus making your launch quicker. The old timer's trick was to use a Vega Converter because it was for a 4 cyc. engine and it had a higher stall than a v-8 converter. Hope that helps! |
thanks tom hand and woody.thats what i was looking for
