Old 05-15-2018, 01:06 PM   #1
jcramsey
jcramsey's Avatar
62 c20 step notch placement question
Starting to mock up my welderseries step notch on my 62 and I was wondering if I need to just center it up over the axle or push it a little forward (I think?) to compensate for the arc of trailing arms. The notch is only 3 1/2 inches wide at the top so not a ton of room for error.
Thanks!
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 05-16-2018, 05:47 PM   #2
tinydb84
tinydb84's Avatar
Re: 62 c20 step notch placement question
You definitely want to set it forward. You can calculate the forward movement or use a piece of string on the ground to replicate the movement.
David
Instagram: myfabguy
Old 05-16-2018, 08:40 PM   #3
cooperhw
cooperhw's Avatar
I move em forward 1/2 inch.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 05-16-2018, 09:16 PM   #4
jcramsey
jcramsey's Avatar
Thanks guys...I’ll move them 1/2” forward, then check with a string.
The Egg Hauler
The Government Mule
Old 06-27-2018, 05:50 PM   #5
Bentbolt
bumping a old post. I know when slamming a truck the wheel isn't centered in the wheel well. can I center the step notch up in the wheel and slid cross member back to make it look better?
Bentbolt is offline   Reply With Quote
